SES light, EVAP?!?! help....
Old Jan 8, 2006 | 01:09 PM
69z-28's Avatar
well i was planning on doing long tubes and a tune and other stuff very soon, so i am buying wires and plugs as well. the only thing that was wrong with the car was it had a very very small mis, that was almost only detectable with a scanner. anyways i planned on fixing that cause i was sure a plug/wire change would eliminate it. so i was going to work yesterday and my SES light came on. i went to autozone today and its a P1441 Aux Emmisions control fault. which when i looked up came to be this...
Evaporative Emissions (EVAP) system flow during non-purge
what does that mean and what will it take to fix it? i wish it was somethign simple that i could say o i can fix that, but i dont know what this means. please help!!!
Old Jan 8, 2006 | 02:54 PM
matLT1's Avatar
Re: SES light, EVAP?!?! help....
you could try testing your evap solenoid
Old Jan 8, 2006 | 03:07 PM
P1441 sets when the flow switch senses vacuum, and there is not supposed to be any. Two possibilities - the EVAP purge solenoid (#7) is stuck open, allowing flow during non-purge, or the flow switch (#11) is faulty. A 3rd possibility is that you have the vacuum lines switched on the purge solenoid, not likely if you haven't changed anything lately.
Shoebox has a diagram of the EVAP system on his website:
Old Jan 8, 2006 | 03:52 PM
69z-28's Avatar
alright cool, thanks for the good info. well the only thing that i can tell is wrong with it is the small misfire it has, so should i just tune it up, do the exhaust i was planning on and then delete the EVAP system with the Madz28 tune i plan on getting? would it be a smart choice to do this, to me it seems best but if someone can tell me a reason not to, id appreciate any more info. thanks a bunch.
Old Jan 8, 2006 | 11:28 PM
The EVAP system does not hurt performance in any way (assuming its working correctly). It actually helps fuel mileage a little bit, because it allows the engine to burn fuel vapor that would normally be lost out the tank vent. And, without the engine pulling the collected fuel vapor out of the canister, eventually you will get a lot of fuel smell at the rear of the car. If you really have flow in the line when the EVAP solenoid is supposed to be closed, it might cause a misfire, particularly if it was a vacuum leak.
Old Jan 9, 2006 | 06:41 PM
69z-28's Avatar
what do you suggest i do? something besides deleting it? im going with a tune in a few weeks here where ill be deleting rear O2s and the smog pump so should i go with the EVAP system delete as well?
Old Jan 10, 2006 | 11:34 AM
Deenasty's Avatar
dont delete the evap system. It doesnt hurt performance, and if you remove it, your eyes will cry with the smell of fuel inside the car..
Old Jan 10, 2006 | 11:59 AM
Colin91Z's Avatar
The solenoid is really cheap so there is no reason to not replace it. Like was stated above, it does nothing to slow you down, so I don't know why you would want to delete it especially since it keeps your car from smelling and actually helps mileage. The part # in the diagram is correct. I just bought one yesterday and it cost me $17. just my .02
Old Jan 18, 2006 | 04:41 PM
69z-28's Avatar
which part is it? i think i might have the car looked at professionally at a place that is well known to make cars pass.
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
