SES Light/ Bad Miss
Old Mar 12, 2007 | 09:47 PM
  #16
94_PatriotRed_Z's Avatar
How who I go about taking off the ICM so I could go have it tested at advance?
Old Mar 12, 2007 | 10:05 PM
  #17
Originally Posted by 94_PatriotRed_Z
it seems like the problem only happens once the cars warms up to temp and goes into open loop. Should I just go ahead and order a new opti? or wait since that might not be my problem. I am kinda low on money try to get this done here on a college budget
Moparman thank you for all your help so far.
As noted above, overheating of the IC Module is a common problem. Shoebox has a "fix" involving spacing the IC Module off the head.
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
The IC Module is held on by two nuts. Unplug all the connectors for the IC Module and the coil, and unscrew the two nuts.
http://shbox.com/1/coil_loc.jpg
PS: It goes into closed loop when it warms up.
Old Mar 13, 2007 | 08:04 AM
  #18
Thanks for the help Injuneer I will go get it tested today, I always get closed/open loop mixed up
Old Mar 13, 2007 | 11:31 AM
  #19
Advance had a new coil for $15 so I tried that, but it still has a bad stumble when I step on it hard, so maybe its the ICM they couldnt test it. There was corrosion on both the coil and the wire that connects the coil to the opti, advance didnt have any wires for an lt1, should i go ahead and order some from summit?
Old Mar 13, 2007 | 02:13 PM
  #20
moparman's Avatar
Take the ICM to Autozone. If the harnesses are in bad shape, you should replace.
Old Mar 13, 2007 | 02:42 PM
  #21
I took the ICM to both Advance and Autozone and both of them said they couldnt test the ICM.
Old Mar 13, 2007 | 03:48 PM
  #22
moparman's Avatar
Did the guy at Autozone look it up to see if they could test it?
Old Mar 13, 2007 | 04:24 PM
  #23
Yea he did, he said they no longer have the machine to test ICMs. I just went and bought a new ICM and and will try it. Hopefully it fixes the problem. I have posted on my local f-body board too and one guy agrees that it probably is the ICM, since it keeps giving me problems once it heats up, but another guy says that code 36 Hi Res is directly related to the opti
Old Mar 13, 2007 | 06:19 PM
  #24
Well I just took it for a test drive and its still stumbling when I step on it hard, then it will throw the code a be ok. So I guess it is the opti. I have a datalog from datamaster I did the other day, if anyone would like to look at it I can email it to them. Thanks everyone for their help so far
Old Mar 13, 2007 | 06:32 PM
  #25
moparman's Avatar
I suspected it was the opti. You've got some new parts now. Save the old ones, as you might need them sometime.
Old Mar 13, 2007 | 06:47 PM
  #26
Thanks for all your help... looks like its time to order that opti and install it and while Im in there will go the LT4 hotcam kit along with it
markzzzz
May 8, 2015 09:21 AM
rideordie
May 3, 2015 12:53 AM
captcorvette
Mar 7, 2015 12:37 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
