More Opti problems (Opti I)
Old Mar 13, 2007 | 08:30 PM
MyWifesZ28's Avatar
Here we go...the car had Opti symptoms (Optispark I), removed cap and the rotor was melted severely at the distributor mounting surface....replaced with el cheapo cap and rotor kit, reassembled car ran for about 10 minutes, then quit, took back apart and same symptoms..I plan on replacing with MSD Distributor, Is this the right path?
Old Mar 13, 2007 | 08:35 PM
93v8clone's Avatar
absolutely if you keep meltin rotors theres a major situation there and the msd unit from what i heer is a stout unit
Old Mar 13, 2007 | 08:38 PM
mdacton's Avatar
what part is it that is melted? there could be another problem......
any pics?
Old Mar 13, 2007 | 08:43 PM
MyWifesZ28's Avatar
Will have pics tomorrow...it is at the base of the rotor that is melting(mounting surface), the plastic is deforming around the T8 screws.
Old Mar 13, 2007 | 09:11 PM
LTgun_94's Avatar
That would be a big negative... my MSD was a piece! I am going to call and complain tomorrow. For $500 it cost me about a year in down time and no telling how much $$$! I am set against MSD, unless they handle my complaint quickly i will not b referring anyone to MSD!
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
