SES light
Old May 1, 2011 | 10:45 AM
Nickw059's Avatar
SES light
my SES soon light comes on only when idiling, when it comes on, it kicks on my fans too. possible coolant temp sensor??? No fault codes are present at all not even when the light comes on! its a 94 z28. anybody diagnose anything similiar?
Old May 1, 2011 | 01:02 PM
Re: SES light
Many codes cause the fans to come on with the SES light, not just the coolant temp sensor.
How are you scanning it? If you aren't getting codes you aren't doing it correctly.
Old May 1, 2011 | 01:24 PM
Nickw059's Avatar
Re: SES light
I have been scanning it with my scanner. obd1 scanner. its saying no active or logged codes or present.
Old May 1, 2011 | 03:39 PM
Re: SES light
Highly unusual. Has the scanner picked up codes on the car before?
Check the fuse for the AIR pump. That's a common code that turns on the fans.
Old May 1, 2011 | 05:46 PM
Nickw059's Avatar
Re: SES light
I haven't had the scanner pull codes off that car car before, but i've done diffrent vehicles with obd1 and 2, thanks i'll check that out!
Old May 1, 2011 | 06:24 PM
moparman's Avatar
Re: SES light
Does your scanner need a power source? The port on the '94 doesn't supply power.
I had an Autoxray once that "failed to communicate". Turns out there was an internal flaw in the scan tool. I was allowed to turn it in for the newer model, which was a much better unit. I did have to pay $100 because I wanted the extra cables and enhanced mode. Still a good deal.
Old May 2, 2011 | 06:59 PM
Nickw059's Avatar
Re: SES light
I'm pretty sure my scanner is fine, but i'm thinking of taking it too a shop too pull codes, I have a can obd1 and obd2 scanner. Its the same one as snap on and many auto parts stores have.
Old May 2, 2011 | 09:50 PM
Re: SES light
You just can't beat a simple Auto Xray OBD-I scanner, a ScanMaster LT1, or the TTS DataMaster, Freescan, and pcmcomm scanning software for pulling codes.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
