Help miss after 5mins of driving
Old May 1, 2011 | 08:24 PM
DTRJAR's Avatar
Question Help miss after 5mins of driving
95 z28 info in sig ok runs good at first then it starts missing after 5 mins or so coming up with code for map sensor would that cause it to miss like that and if i shut it off for a lil it will be ok for like 5 mins again help plz thanks
Old May 1, 2011 | 10:02 PM
Bykerboy869's Avatar
Re: Help miss after 5mins of driving
check the plugs and wires. my car was misfiring cuz i got some liquid on a sparkplug but wiped it off with a papertowel and didnt misfire anymore.
Old May 1, 2011 | 10:55 PM
DTRJAR's Avatar
Im going to put new in soon
Old May 1, 2011 | 11:19 PM
What have you done about the code for the MAP sensor? Which code is it?
How old are the O2 sensors?
Old May 1, 2011 | 11:52 PM
DTRJAR's Avatar
O2 not so good have new on way map I tried a old one but it made it worse... Will the map make it be like that and what not thanks
Old May 2, 2011 | 08:14 AM
jon_7687's Avatar
The O2 sensor will make it run like crap if its bad.
Mine did the same thing. Drove just fine for the first few min, then when the engine warmed up enough to go into closed loop it started to run like its only hitting on 3 cylinders.
Replaced the sensor and it runs perfect now.
Old May 2, 2011 | 05:00 PM
The MAP sensor is used as a measure of engine load. It is one of the axes of the ignition timing map. It (along with rpm) is also the basis for defining the closed loop fuel correction cells. It is also used if the PCM needs to switch to speed-density.
Old May 2, 2011 | 06:28 PM
DTRJAR's Avatar
My car won't go in to closed loop why is this
Old May 2, 2011 | 09:55 PM
Three things have to happen:
-coolant temp exceeds ~140*F
-O2 sensors hot (>600*F) and generating a voltage
-PCM timer to closed loop times out (usually about 205 seconds)
How did you determine it's not in closed loop?
Old May 2, 2011 | 10:01 PM
DTRJAR's Avatar
Datamaster
Old May 2, 2011 | 10:10 PM
And does the closed loop flag bit not set to "1"?
Old May 2, 2011 | 10:40 PM
DTRJAR's Avatar
Dont know what u mean all I know is up in the right side it has open and after 30 mins of run time it has not went to closed
Old May 2, 2011 | 11:10 PM
In the upper right side of the standard DataMaster screen there is a box with binary bit indicators of various functions. One of them can be set to indicate "closed loop". "0" = open loop; "1" = closed loop. Then there's the top status bar that indicates a bright green "Closed Loop" on the 3rd box from the right, which I believe is the one you are referencing.
What is the coolant temp indicating when it's not in closed loop after 30 minutes? What is happening to the left and right O2 sensor volts when it's not in closed loop after 30 minutes? What cells is it operating in?
Might also not let it go into closed loop with the MAP code active, because it would prevent it from using the correct cells for learning and for fuel correction.
Old May 2, 2011 | 11:41 PM
yanal_zegra's Avatar
i just fixed that problem in my car two wire were cut and did a whole tune ups for the car also check that the cat is not clogged
armedtrigger
Feb 24, 2015 08:30 PM
Fatdog2
Feb 13, 2015 08:19 PM
DetroitZ28
Feb 13, 2015 07:33 AM
dgPltt
Feb 11, 2015 07:04 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
