ses code o336 crankshft position sensor?
Old Jun 8, 2004 | 08:52 PM
MonkeyManZ28's Avatar
Angry ses code o336 crankshft position sensor?
just dropped in a new engine in my z and its running a bit rough. it has the code p 0336 for the crank position sensor. it has the lt4 hot cam and ported heads. is it just the sensor or what can i do or look at. it also has code 0131 for the bank one o2 sensor, but i replaced it. if anyone knows help me i haven't driven the z in 6 months!!!!!!
thanks
Old Jun 8, 2004 | 08:59 PM
disco192's Avatar
who put the opti back on?
Old Jun 8, 2004 | 09:04 PM
what about the opti? they still haven't adjusted the roller rockers could that be why its running rough or is it something else. i only have the two codes:
p0336 and
p0131
thanks
Old Jun 9, 2004 | 06:25 AM
Why would you run it without adjusting the valves? Has it been tuned for the heads & cam?
If its running really rough.... with the cam, no tune, and the lack of a valve adjustment.... the crank position sensor is going to be putting out vibration patterns that the PCM can not recognize. That alone could set the code. If it was faulty wiring or a bad sensor, I think you would get P0335.
Get it set up properly, and see if the code goes away.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
