SES Code 26, replaced PCV Valve....
Old Aug 8, 2006 | 08:49 AM
The Captain's Avatar
Hello all, I am getting a Code 26 so I replaced the PCV Valve and the light is still on. It does not come on immediately, usually a min or so after startup. Do I need to reset the computer to clear the code, or is there still in fact still something wrong? The car runs and drives fine, any thoughts?
Old Aug 8, 2006 | 09:53 AM
camaroman4ever's Avatar
Re: SES Code 26, replaced PCV Valve....
for some reason I am thinking 26 comes up when the air pump fuse is blown. Might check that.
Old Aug 8, 2006 | 06:50 PM
DTC 26 on a 1993 is (courtesy of Shoebox):
Quad-Driver Module (QDM) #1 circuit applies to:
- AIR pump relay circuit
- EGR solenoid
- EVAP solenoid"
The code has nothing to do with the PCV valve. In fact there are no codes at all related to the PCV valve.
One of the devices listed above has an electrical fault. I'll say its probably a blow fuse for the AIR pump. If that's not it, check the EGR and EVAP solenoids. If all those are OK, it could be a faulty quad driver module, a component in the ECM case.
Old Aug 9, 2006 | 08:44 AM
- EGR solenoid
- EVAP solenoid"
Oh, thanks! for some reason I was thinking the PCV valve was causing the code. I will go out and check the fuse in a few. Is there any reason why it would be blown?
Old Aug 9, 2006 | 09:53 AM
Sure... the pump rusts up, get harder to turn and starts to draw higher amps, blowing the fuse.
Old Aug 14, 2006 | 01:38 PM
Ok, I checked the fuse, it was fine. I then checked the air pump relay and it is working fine as well. Does anyone know exactly where the EGR and EVAP solenoids are?
Gtpguy
Jan 26, 2015 04:50 PM
Jazsun
Dec 29, 2014 12:14 PM
91Bird305
Aug 5, 2002 01:39 PM
Z28Wilson
Aug 1, 2002 04:27 PM
jrp4uc
Jun 28, 2002 09:48 AM
