service engine soon light, fans stuck on. help
Old Feb 23, 2004 | 08:18 PM
KeVMaN's Avatar
Well, I got my car back from the shop (had a new tranny installed), and on the way home, I get an SES light. I notice that my fan switch is off, but both of the fans are goin, and the temp is good, around 160-180. Somethings telling the car that its overheating, when its not. Anyone know what the problem might be? thermostat?
Old Feb 23, 2004 | 08:59 PM
Van5150's Avatar
I have same problem. Check your Air Pump fuse, is it Blown ? It is located in engine compartment.
Old Feb 23, 2004 | 09:04 PM
Hyperspeed97z28's Avatar
I had problems with the air pump fuse as well..
Well until I removed it..
I'd check the fuse for that first.. Might be that simple for you
Old Feb 23, 2004 | 10:22 PM
KeVMaN's Avatar
wheres it at in the engine compartment?
Old Feb 23, 2004 | 10:23 PM
blazzinbird's Avatar
I also had the same prob, it was my maf plug wiggled off somehow
Old Feb 23, 2004 | 10:26 PM
In the underhood fuse/relay center behind the LH headlight. The fans come on because of the SES-that's normal.
Since you have a 1993, you can pull trouble codes yourself and see what the SES is for.
Old Feb 23, 2004 | 10:56 PM
KeVMaN's Avatar
I don't have a maf
Old Feb 23, 2004 | 10:58 PM
KeVMaN's Avatar
ah thanks a ton man. Is that the little port thing in the driver kick panel?
Old Feb 23, 2004 | 11:55 PM
Should be by your right knee, bottom edge of the dash.
Old Feb 23, 2004 | 11:59 PM
KeVMaN's Avatar
Anywhere that shows a list of codes? I know my camaro book lists them but thats at my dads house
Old Feb 24, 2004 | 12:06 AM
Look no farther than my Tech Page.
Old Feb 24, 2004 | 02:13 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Haha, yeah, shoebox's tech page is on my favorites list......
Old Feb 24, 2004 | 04:40 AM
Amped96's Avatar
So does an SES light always cause the fans to stay on?
Old Feb 24, 2004 | 08:12 AM
In most cases, it triggers the fans.
Old Feb 24, 2004 | 10:17 AM
Amped96's Avatar
OK..makes me feel a little better. Mine have been running an awful lot I thought. I have several codes triggered by removal of air pump, egr, rear O2s, and the like. Guess i should hit up pcmforless sometime. Thanks for the info.
