service engine soon light, fans stuck on. help
Old Feb 24, 2004 | 09:43 PM
  #16
KeVMaN's Avatar
Alright, did the little trick, got a code 43, which according to the book is a bad knock sensor or connection. If my knock sensor is bad, would it automatically pull the 10* of timing out? That would explain the massive loss in performance. I used to pull my friends 94Z pretty well with my slipping tranny (he's stock and 2.73) and I got my *** handed to him today with my new built 700r4. The car is just absolutely gutless at low rpms, won't even spin the tires... and I have a 2500 stall converter, racing clutches, bigger boost valve, shift kit, and 3.23's... it should be spinning for blocks. So yeah anyway, replace the knock sensor? its only like 30 bucks
Old Feb 25, 2004 | 12:30 PM
  #17
KeVMaN's Avatar
Old Feb 25, 2004 | 12:34 PM
  #18
Robs97Z28's Avatar
I would! it is cheap enough and sounds like it would solve your problem.
bfmv13trivium
Jan 14, 2015 09:57 AM
30thZ4C
Dec 26, 2014 05:09 PM
ro2207
Dec 4, 2014 06:18 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Jul 4, 2005 05:00 PM
