Serpentine Belt Gets eaten...
Old Jan 29, 2006 | 07:37 PM
6SpdLT1Z's Avatar
OK, so I put a new serpentine belt on EARLY Janaury 06 and I replaced the Gates ($35 O Reilly) belt that the previous owner had put on recently. It was frayed REALLY BAD and ended up braking (causing me to lose power steering)
And anyway, I was under the car a couple days ago and noticed my new (heh $12 Oreilly belt) already fraying. Anyways, I figured the tensioner needed replaced or something. I had the car at NTB to have the suspension looked at (I need Lower Ball Joints) and I had them look at the Serpentine Belt... They said everything looked fine except the AC Compressor pulley.. Its making a tick tick tick noise and they said they think the bearing is going out.
Can I just replace the pulley or do I need a whole new AC Compressor? Any tips on doing it? etc.
Old Jan 29, 2006 | 07:48 PM
kick Z tail out's Avatar
Re: Serpentine Belt Gets eaten...
Back when I had my 94 Z28 in 2001 I shredded and lost 5 belts on the road. Very annoying. I also knew very little about working on my own car, but I did know how to replace the belt... Which I did. I just couldn't track down and fix the problem that was causing it.
So I took the car to the stealership (yeah I know) and they told me it was the A/C compressor as far as they could tell and told me I would need to replace the whole piece for $800. I instead went with the 1LE A/C delete pulley.
The belt still shredded on me a couple months later... when the power steering seized on me. Don't know if that's what was doing it all along or if it was just a symptom. I never found out what was causing it before I had to sell the car. Obviously I had an out of balance pulley somewhere if it wasn't...
Anyway, hopefully you've found the problem and you don't have a repeat of my nightmare. Good luck... and screw the dealership. I'm sure they would have loved following their standard operating proceedure of replacing EVERY accessory on the front end by emptying my wallet.
Old Jan 29, 2006 | 08:15 PM
6SpdLT1Z's Avatar
Thanks for the input Nate. But the 1LE pulley gets rid of the A/C all together right? Don't realy care to do that since it's my DD. Anyway, I need to figure out if I can just replace the pulley. Hopefully thats the case but if not then I guess I'll have to buy a new A/C Compressor. Stupid car.
Old Jan 29, 2006 | 08:19 PM
Yeah it did... I had always said I would put it on later, because I couldn't stand the car not having A/C.
I would never do that to my current Z.
Old Jan 29, 2006 | 11:02 PM
1racerdude's Avatar
Ya can replace most clutch and pulley assy's on the AC.
Call and get a price and take it to an AC place and have it changed and the system checked.
Old Jan 29, 2006 | 11:28 PM
Check the damper. Its made in 2 pieces, with a hard rubber ring connecting the inner and outer halves. The rubber ring can dry out and break, letting the outer ring on the damper (which is the pulley) wobble.
Old Jan 30, 2006 | 11:32 AM
6SpdLT1Z's Avatar
Is putting a 1LE Pulley on a easy 15 min bolt-on job? Or do I need to remove the AC Compressor?
Old Jan 30, 2006 | 12:43 PM
PM sent.
Nah unfortunately the compressor has to come out... The 1LE setup is the pulley, and a triangular brace that bolts into the place of the compressor.
Here are some pics of what it looks like:
http://www.miamimotorsports.com/1le.ht1.jpg
http://www.projectgangreen.com/Insta...s/DSC00389.jpg
Old Jan 30, 2006 | 01:42 PM
multicar's Avatar
Take it to a decent A/C shop and they'll replace the clutch bearing without having to drain the freon. Cost me $200.
Doug
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
