cranking problem
Old Jan 3, 2006 | 10:50 PM
aarontracy's Avatar
cranking problem
when my car hasnt been run for about over an hour it has a hard time starting. i turn the key and it shoulds like the starter is hitting fine but it just wont turn over. if the car has ran for a little bit and i turn it off and turn it right back on it starts fine.
Old Jan 4, 2006 | 06:07 AM
Guest47904's Avatar
Guest
Re: cranking problem
The next time you have the problem, try holding the throttle to the floor while you crank it. Starting easier now would indicate a fuel leaking issue into the intake.
If that doesn't help the problem, the very next time you have the problem, try cycling power KOEO and then off. Do this 6 times and then start it like normal with out touching the throttle. If it starts easier after this, it indicates the fuel is draining away from the fuel rail and is probably the check ball in the fuel pump causing the problem.
Let us know which way starts easier and we can point you to the problem.
Also check the oil for the smell of fuel just in case.
Old Jan 30, 2006 | 02:26 PM
transAMdriv3r's Avatar
yeah my car a 1994 trans am, is having the same problem. the starter sounds fine, the battery is fine they only way it will start is if i floor it or keep the starting turing till it slowly builds rpm
RUENUF
Mar 13, 2016 03:39 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Scottyboy
Feb 11, 2015 10:28 PM
1LEThumper
Jul 14, 2003 12:45 PM
