Which sensors?
Old Sep 28, 2006 | 12:44 PM
carguy2112's Avatar
Which sensors?
Some of you may have read my previous post conserning my injectors not firing. I was thinking it was a pcm issue, but after further research, I'm beginning to think sensors. The question I have is which sensors will cause the pcm to not fire the injectors and how do I check them?
93 Formula LT1 a4
Old Sep 29, 2006 | 09:11 AM
carguy2112's Avatar
Re: Which sensors?
Anyone?
Old Sep 29, 2006 | 10:34 AM
97bowtie's Avatar
Re: Which sensors?
How have you determined that the injectors aren't firing?
Old Sep 29, 2006 | 11:14 AM
Re: Which sensors?
The only "sensor" that will cause the PCM not to fire ALL the injectors is the optical module in the OptiSpark. If the PCM does not see the low res pulse pattern from the Opti, it shuts down the injectors and the fuel pump. But that's ALL of them, not just a few.
Many of the other sensors affect the pulse width of the injectors, but none of them prevent them from firing. The PCM will shut the injectors down on deceleration, in certain RPM ranges.
If you are referencing a problem you have discussed in another thread, its generally a good idea to include a link to that thread so people can review your problem. With 58,000 members, its not likely that people will remember past posts.
Old Sep 29, 2006 | 12:24 PM
carguy2112's Avatar
Re: Which sensors?
Sorry about that Fred. Here's the link to the other thread - http://web.camaross.com/forums/showt...starting+issue
I pulled the rail with everything still hooked up and had a friend turn the engine over. I didn't get any fuel out of any of the injectors.
If the opti is the only thing that will shut them all down, I don't think thats it. I can here the pump come on and I am getting 44 lbs of pressure.
Correct me if I am wrong. If it's not the opti, then next thing to check would be harness and injectors (can't see all 8 going at the same time but you never know). If they check out, the only thing left is pcm right?
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
