Self Align Rockers with Beehive springs?
Old Jul 28, 2007 | 12:09 AM
CreatiVe2's Avatar
Just as title says, i have done a lot of searching and havent come across a solid answer basically i got a slightly used set of 3/8 SA 1.6 pro mag rockers, in LE heads and i want to go with the beehive springs. are there any issues with pairing the SA rr's with these springs?
Old Jul 28, 2007 | 12:14 AM
colossus's Avatar
mine arent 1.6, but they're SA and i've had no problems so far... now i just hope somebody doesnt post saying my engine is gonna explode in a bit.
Old Jul 28, 2007 | 12:44 AM
OldSStroker's Avatar
Aren't all Comp ProMag SAs 3/8 studs? If you are using fairly aggressive cam lobes which make your heads work as they were dsesigned to, the 7/16 studs might be a better choice.
I suggest that you discuss this with Lloyd or Bret.
Jon
Old Jul 28, 2007 | 03:33 PM
CreatiVe2's Avatar
yeah i was planning on going with a LE2 cam, but would i be a bad choise to go with somethign less aggressive, i really dont want to get ride of this setup i just purchased :/
Old Jul 28, 2007 | 03:46 PM
Stl94LT1's Avatar
The only problem you may have is when using +.050 locks with the SA rockers. This will leave very little valve stem for the rockers to align.
Noenav
Mar 1, 2019 07:38 AM
Drtryder
Apr 22, 2015 04:17 PM
95chwagon
Jan 13, 2015 09:19 PM
