head cc ######
Old Jun 14, 2003 | 10:26 PM
akafred's Avatar
head cc ######
i got lt1 heads that are ported and shaved 10 thou what would the combustion chamber cc be approx?
what are the stock cc?
at 56cc my motor will be 12.09:1 compression
Old Jun 14, 2003 | 10:33 PM
94Sleeper's Avatar
I just got mine back from AI. I wanted 52 cc chambers so Phil decked them .014. Chambers are now 52.3 cc
Old Jun 14, 2003 | 10:39 PM
Prorac1's Avatar
stock lt1 heads are 58 cc, so your compression will be under 11.9, but i think on pump gas your still screwed
Old Jun 15, 2003 | 09:25 AM
arnie's Avatar
Originally posted by Prorac1
stock lt1 heads are 58 cc....
If they are, how could sleeper's have been more like 54 1/2 cc? (1cc to appr. .007") Remember, his were actually checked. While many may check out 57-58 oem, the specs are actually 54 cc for LT1. ( Or is it 54.4 cc? ) Anyway, to blanket ALL LT1 heads as being 58cc without an asterick would be misleading.
Old Jun 15, 2003 | 10:33 AM
akafred's Avatar
with 58cc my compression is
11.78:1
Old Jun 15, 2003 | 10:42 AM
RUFFIDLNZ's Avatar
I have always heard LT1 heads are either 53 or 54cc. How can there be this much difference in cc? I can understand the 53 or 54 but range from 53-58???????????
Old Jun 15, 2003 | 11:05 AM
arnie's Avatar
Just cuz someone posts figures, doesn't make them accurate.
......but range from 53-58?
Consider that the range of ACCURACY of various posts.
However, (and this has been posted several times here) oem blocks AND heads are assembled with extra stock on their respective surfaces. Figure .015-.020" on average. Without exception? No, but in a small minority.
I edited this post to rephrase one sentence to make my point more clearly understood. By that I should have stated that is the range of INACCURACY of various posts. My range would be from 54, (which is unlikely) to 57 1/2 (with .020" extra stock on head).
Old Jun 15, 2003 | 12:49 PM
Josh-'04 GTO's Avatar
It's not 58cc. I've always used 54cc for a good starting point, but, measuring is always best.
Many cars on this board(mine included) have run mid 11:1 compression on pump gas with no problem. Over 12 is pushing your luck though.
Old Jun 15, 2003 | 06:01 PM
arnie's Avatar
That starting point that you state you use; I'm interested in knowing whether you have achieved that figure with accurate measuring, or is your starting point just a estimate/guess? Also, are you measuring the various volumes accurately to arrive at the 'mid 11:1' ratio, or again, is that an estimate?
Old Jun 15, 2003 | 06:07 PM
52.5cc with .010" milled off, .029" Impy head gaskets and 11.4:1 compression. I do know how to figure out a compression ratio, but thanks.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
