Security Light on car wont start
Old Oct 7, 2003 | 06:59 PM
  #61
Ponykillr's Avatar
i moved the wires from under the cage they are kinda squashed but none have insulation striped off. I turned the key to on and the security light came on for about 2 seconds then went off. I turned the key to start usually the fuse blows but this time it did not instead the starter tried to turn over. The car gives an SES light and the secruity light comes on for another 2 seconds.
I think the fact that it does not keep cranking is because of a dying battery. Also i never hear the fuel pump come on at all.
Old Oct 7, 2003 | 07:02 PM
  #62
Lyle A's Avatar
I think you cleared your short. Now you have a different problem. Start by charging the battery. Make sure everything else is hooked back up.
Old Oct 7, 2003 | 07:16 PM
  #63
Ponykillr's Avatar
would i need to repair the wires that were pinched or once they are un pinched they are good again? Also when should the fuel pump engage?
After it tries to crank it just stops and makes a loud clicking noise.
Old Oct 7, 2003 | 11:45 PM
  #64
SageofKnight's Avatar
I'm having the same problems, my car just isn't starting and the security light stays on.
Old Oct 8, 2003 | 03:37 PM
  #65
Ponykillr's Avatar
well the cars starter works fine it tries to crank. Fuel pump never comes on though. When the key is turned to start the SES light comes on and the security light comes on but it goes off in about 2 to 3 seconds. Fuel pump nerve engages.
Old Oct 8, 2003 | 03:43 PM
  #66
LT1 Bunny's Avatar
Josh...when you go to start the car does it just make a loud clickling noise over and over again while your turning the key?
Old Oct 8, 2003 | 03:52 PM
  #67
Ponykillr's Avatar
no it actully engages the starter
Old Oct 8, 2003 | 03:55 PM
  #68
2nd2none's Avatar
I have an extra lock cylinder with a key that came off a 94 Z, Ill let it go for $14 shipped if anyone needs it. Both are in very good condition.
Old Oct 8, 2003 | 03:58 PM
  #69
Ponykillr's Avatar
ill just bypass it if i have too. i think the key thing is good it makes the click click click sound
Old Oct 8, 2003 | 10:11 PM
  #70
LT1Bunny's Avatar
Lyle A : Thanks for all of your help! I made it over to his house today and we figured out the problem in minutes! Everything is running great and I hope we can get this dash back together with no problems. It actually was the fuel pump...for some reason when the wires were crimped, it wasn't sending the right signal. So I think that they are fine and don't need to be replaced. But again...thanks for the help!
-Eddie
Old Oct 9, 2003 | 12:03 AM
  #71
Lyle A's Avatar
I appreciate that. But, Ponykillr and yourself are the ones that deserve the credit. I just just gave you the routes and through elimination the right path was found. Welcome to the world of troubleshooting. I'm glad it's fixed.
Old Oct 9, 2003 | 02:03 PM
  #72
Ponykillr's Avatar
Took the battery in today and it was part of the problem also. Thanks Lyle A and Eddie I sure am glad to here it fire up again. Give me a call Eddie and we can get it finnished up Ill have all teh insides back together today. Hope the weather clears for the weekend.
bfmv13trivium
Jan 14, 2015 09:57 AM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
