searched, but still confused about timing dot alignment
Old Apr 13, 2005 | 10:15 PM
dynomight's Avatar
when installing the cam sprocket in relation to the crank sprocket. setting the crank dot at 12 oclock, #1 tdc. setting the cam dot at 6 oclock.
now when rotating the assembly, the crank rotates two times for every one cam rotation. does it make a difference if (assuming the cam dot is in 6oclock position) the crank dot is on its 1st rotation or 2nd rotation? or is it as simple as dot to dot?
i hope its clear enough, if not, ask and i will try and clarify. thanks for the help.
jb
Old Apr 13, 2005 | 10:17 PM
97bowtie's Avatar
Re: searched, but still confused about timing dot alignment
It's as simple as dot to dot.
First or second revolution is only relevant when the cam is rotating w/the crank. When the crankshaft gear dot is at 12 0'clock, the crank is always in the same position.
markinkc69z's Avatar
Doesn't matter, and you can't tell one rotation from another.
Old Apr 14, 2005 | 04:17 PM
dynomight's Avatar
thank you my friends
jb
oldschool
Feb 9, 2016 09:21 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
Dec 1, 2014 08:08 AM
