Sealing the Opti!!!!
Old Oct 2, 2008 | 01:04 PM
xxxtreme36's Avatar
Has anyone ever tried or been fairly successful sealing a new opti? if so how did you go about doing so? Im getting ready to put a new one on and id like it to last as long as possible. Thanks
Old Oct 2, 2008 | 03:37 PM
importsleyer's Avatar
sealing
I used rtv black on both sides and around the top of the plug and then ran small bead around the rim and then bolted it together while once it was tacky.
Old Oct 2, 2008 | 05:26 PM
jer4251's Avatar
would it be a good idea to put loctite on the rotor bolts? ive heard they could come loose.
i'm buying a delphi opti tonight, and would like to know because with my car, the car revs up to 6800 rpm. way more than the stock opti asks for.
Old Oct 3, 2008 | 07:32 AM
xxxtreme36's Avatar
thats what i eneded up using, but i did not take mine apart, just ran ultra black with the two pieces come together and anywhere else water or fluids could come in
Old Oct 4, 2008 | 06:54 AM
NukeFPE's Avatar
I do it all the time on both vented & non-vented optis. On the non vented (94 and older) I actually drill 2 of the lower vent holes & tap & plug them w/ 10/24 screws. The hole nearest Cylinder 1, drill out 3/16 & install a 90 degree fittilg. On the cap, I'll install a vacuum fitting by melting an opening w/ soldering iron & epoxy-ing it in the same location as the post 94 ~ then use the GM 95 & up vacuum harness.
Now, putting the opti back together, ALWAYS use lock-tite on the two rotor screws. On each of the interfaces e.g. between the cap & aluminum body ~ I'll run a small bead of OEM black silicone. When the opti is all together, I'll run a bead around the interfaces to finish it off. This helps the vacuum work & keeps out moisture.
For the vented opti ~ I'll take the new one apart, Lock-tite the two rotor screws & silicone the interfaces on re assembly ~ just be neat ~ it does not take much silicone!
One more thing on moisture ~ your biggest problem is the weep hole in the waterpump. Take a 1" piece of 3/16" steel brake line & epoxy it into the weap hole leaving about 1/2 sticking out. Then install a length of 3/16" rubber hose & route it so it discharges under the car and not on the opti ~ Its also much easier in the future to pin point when the water pump is leaking.
Old Oct 4, 2008 | 12:38 PM
mpe331lx's Avatar
Great idea!
Old Oct 5, 2008 | 09:17 PM
77amc's Avatar
After reading all these horror stories about the opti's, I think that when i do the head job, I'll take it apart and seal it up with that pump trick.
I just bought this car last week for cheap 'cause of the heads but with this opti fix maybe i'ts gonna run for a while.. ??
Jlo
Jul 29, 2015 03:52 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
