Sealing Canton VCs
Old Jun 1, 2008 | 01:11 PM
FlamingChicken's Avatar
Sealing Canton VCs
Just got mine the other day and looking at them im not sure if they require a gasket or a liquid sealant like "the right stuff". only seen one pic of a guy with an actual gasket on the covers and it doesnt look right to me. Probably gonna try the right stuff unless somebody has bad experiences using that on valve covers. Anybody know for sure?
Old Jun 1, 2008 | 03:16 PM
Sinister95Z's Avatar
Just use a rubber Fel-Pro gasket. It looks a little wierd because the valve cover does not sit down over the gasket. No sealant is required, but it will leak if you do not use a gasket.
Old Jun 2, 2008 | 06:53 PM
thanks for the reply. gonna get some today. for anyone searching this in the future i would not recommend using "the right stuff" over a standard rubber gasket simply because of valve adjustments. completely forgot about them and having to clean and scrape all that **** off every time you take them off.
Old Mar 4, 2009 | 11:45 AM
SomeGuy25thZ's Avatar
im bringing this one back people... I am running into the same issue. I mocked up the canton valvve covers with the rubber gaskets and I am worried about how they sit. Do you guys rely on a compression fit and does it or will it leak? or do you use some kind of sealant material along with the gasket to help it seal right?
I posted pics on thirdgen.org (383 LT1 swap into a 92z)
http://www.thirdgen.org/techboard/sh...2&goto=newpost
Old Mar 4, 2009 | 12:18 PM
Kevin Blown 95 TA's Avatar
I never did this on Cantons, but on older cars we used to glue the gasket to the VC just for convenience of removing/installing it - make sure it's flat when it sets up if you do it this way. Assuming the Cantons are shaped correctly, this should seal it up.
Old Apr 3, 2009 | 10:30 PM
user 647483's Avatar
I'm not sure what you guys ended up using, but The rubber ones just didn't seem to seal properly in the corners.
I used a set of SBC cork gaskets and just trimmed the perimiter bolt tabs off.
Sealed great.
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
