Seafoam???????????? Car Dies
Old Jun 22, 2007 | 03:06 PM
5H9D0W's Avatar
When I disco the brake booster hose the engine kills. How do I get around this?
Old Jun 22, 2007 | 03:09 PM
2000GTP's Avatar
You probably will need a second person to work the throttle to keep the engine going while you pour the Seafoam.
Old Jun 22, 2007 | 03:29 PM
speed_demon24's Avatar
Unplug the MAF
Old Jun 22, 2007 | 04:06 PM
useful_idi0t's Avatar
i just take the cap off the seafoam, disconn. the brake booster hose, put the cap over it upside down, and start the car
Old Jun 22, 2007 | 04:39 PM
5H9D0W's Avatar
I just used the TB vaccum hose. I did the gas tank with a full bottle, half in the crankcase, half in the vaccum, and I sprayed the cleaner in the intake. I laced my whole block with smoke. I hope it turns out as advertised. I'll keep posted.
Old Jun 22, 2007 | 05:02 PM
ZL1modified's Avatar
what the hell is seafoam?
Old Jun 22, 2007 | 05:14 PM
00ls100's Avatar
it's a treatment that helps remove carbon build up and other crap thats inside the motor
Danny McAdams's Avatar
It is a fuel additive that supposedly stabilizes the fuel especially during storage, when I ran a marina we put it in boat fuel for winter lay-up. It is said to clean carb and valves during normal operation. I would never put it in oil system. I would use Marvel Mystery oil, I know it cleans the oil system, especially hydraulic lifters. Danny Mc
Old Jun 22, 2007 | 05:17 PM
00ls100's Avatar
isn't that sta-bil your talking about?
if seafoam also stabilizes the fuel, i didn't know...
don't want to come off as an a**
Old Jun 22, 2007 | 05:39 PM
Savannah Dan's Avatar
http://www.seafoamsales.com/products.htm
Old Jun 22, 2007 | 06:07 PM
wrd1972's Avatar
I use the small line that goes to the opti.
Old Jun 22, 2007 | 06:12 PM
2000GTP's Avatar
Here is a good walk-through on doing the treatment: http://www.ls1tech.com/forums/showth...hlight=seafoam
Old Jul 10, 2007 | 01:32 AM
5H9D0W's Avatar
The seafoam treatment worked great. I expected my oil to be a little darker but it wasn't that bad, I ran my car on a half a can for 150 miles. The car runs smoother and the response has improved a little. I can't really tell about the gas mileage cause I just filled my tank but I have a feeling it has improved as well. I'm going to definitley do a seafoam treatment right before every oil change.
Ouch, 1 Mobil 1 filter (302)= $12, 5 quarts of Mobil 1 (10w30)= $30, 2 cans of seafoam= $12. Total price $54 at least. I already bought the throttle body cleaner and it should last at least 5 treatments. Has anyone not gotten the white smoke outa the tailpipe after a vaccum treatment?
Old Jul 10, 2007 | 11:09 AM
2000GTP's Avatar
I didn't get a big smoke show from the tailpipes and the engine oil wasn't filthy black either. Either my engine was pretty clean or maybe the previous owner did a Seafoam treatment.
Old Jul 10, 2007 | 01:02 PM
scottso's Avatar
Ditto here. Some smoke - but not extreme like I have seen. Initially I also said, hmm - engine must be pretty clean.
But I did later read debates (here?) about whether the smoke actually is carbon burning off.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
