Screeching starter problem.
Old Mar 22, 2005 | 11:05 PM
lookingforwheels's Avatar
Hello, I was wondering if anybody could help me with my 97 Formula.
Whenever I start the car cold, I hear a loud screech which seems to be coming from the starter, also if I rev it when it's cold it will screech, and sometimes at WOT it will screech. The screech only lasts for a second or two but it is annoying.
I thought the problem was the starter so I replaced it but the screech didn't go away. I bought some washers and I put two of them on each bolt to try and space out the starter but it didn't seem to make any difference.
Should I just keep adding washers? Also does anybody know if the two long/thin gold screws do anything on the starter? Do you have to adjust them? From what I know I believe it still has the stock flywheel if that matters.
Thanks, appreciate any input or ideas.
Old Mar 23, 2005 | 12:39 AM
redsick93lt1's Avatar
Re: Screeching starter problem.
by you saying that it happens when u rev it up makes me think that it might be that you need a new belt. i would check if its worn or if you havent replaced it lately i would do that. i think it is like 30 or so.
Old Mar 23, 2005 | 05:43 AM
slopokrodrigez's Avatar
Like red said, the starter is out of the picture once the engine is running. So your problem is the belt. You should replace the tensioner when you replace the belt and be sure to check any idler pulleys for bad bearings.
BTW be sure the clearance between the flywheel and starter gear is about the distance of a paper clip.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
