Help Us Asap!!!
Old Mar 22, 2005 | 06:23 PM
fredmr39's Avatar
Help Us Asap!!!
I installed OVC plug wires kit in my car today, then we decided to go ahead and install my friends while we were on a roll. At the end of the install for his car, he started the car (or turned the key at least) without putting the serpentine belt on. There was a brief loud noise, then nothing (idk if it stopped or it he stoped turning the key). What should be done now? Try starting it again? What could be messed up??
Old Mar 22, 2005 | 06:25 PM
Propower1124's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Re: Help Us Asap!!!
what kinda car?
i would say just put the belt back on and start it
Old Mar 22, 2005 | 06:29 PM
fredmr39's Avatar
Re: Help Us Asap!!!
96 M6 LT1, similar mods as mine in sig
we put belt on, but it wont start, didn't hold key long - there was a softer noise -- could one of the boots to the opti be not hooked up, would that cause it not to start?
Old Mar 22, 2005 | 06:31 PM
Re: Help Us Asap!!!
does the engine even turn over?
Old Mar 22, 2005 | 06:36 PM
fredmr39's Avatar
Re: Help Us Asap!!!
No - could the starter be the problem? It sounds like its loosely hitting something
Old Mar 22, 2005 | 06:38 PM
fredmr39's Avatar
Re: Help Us Asap!!!
I cant hear anything but a higher pitching turning - engine doesnt turn so damage must be between starter and flywheel
Old Mar 22, 2005 | 06:47 PM
Re: Help Us Asap!!!
Yea most likely ur starter is shot . thats what im gunna say, starter is shot
Old Mar 22, 2005 | 06:50 PM
fredmr39's Avatar
Re: Help Us Asap!!!
Lets hope so, because I'm gonna go to autozone now and hopefully they'll give me another since it had a lifetime guarantee and I got it a couple months ago -- i cant think of anything else that could be damaged, can you???
Old Mar 22, 2005 | 06:55 PM
blitzer454's Avatar
Re: Help Us Asap!!!
Did you maybe loosen the starter to get to plug 8 and forget to fasten it back down before starting the engine? Maybe you don't need a new starter, just need to make sure the gears are going to mesh correctly.
Old Mar 22, 2005 | 07:00 PM
Re: Help Us Asap!!!
good thinkin blitzer,...........yea check that out
Old Mar 22, 2005 | 07:05 PM
fredmr39's Avatar
Re: Help Us Asap!!!
That is good thinking, but i did not loosen it. Im positive its the starter (maybe Im being too optomistic just because i get another for free)
Old Mar 23, 2005 | 01:20 AM
fredmr39's Avatar
Re: Help Us Asap!!!
FYI - starter was shot, took it to autozone and had them test it, it kicks out but the gear does not spin. New one is in, car is all assembled, belt on -- but I cant stand whether it be my car or a friends for something to be unsolved before bed (like when I had header problems during install I was up till 6am in the snow). So I have not yet attempted to start the car again. It should be fine now, but why would a serpentine belt not on blow the starter? Is it because there was no combustion to move the pistons, so the starter just couldn't handle that kind of force?
Old Mar 23, 2005 | 05:47 AM
30696bird's Avatar
Re: Help Us Asap!!!
I'm sure it was just timing................not timing of the car but timing itself. In other words had you worked on it or not it was gonna happen.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
