Scanning for codes in a 93?
Old Jan 6, 2005 | 02:52 AM
Got-LT1's Avatar
Is there any equipment that can scan for codes in a 93? Where would I be able to get one?
Old Jan 6, 2005 | 02:53 AM
Bersaglieri's Avatar
Re: Scanning for codes in a 93?
If you can offord a paperclip you can scan your codes. Do a search on the paperclip mod. Its only available on 93's, so feel lucky.
-Dustin-
Old Jan 6, 2005 | 04:39 AM
Fastbird93's Avatar
Really easy:
Straighten a paper clip out. With the key OFF, insert one end into the top right port on the ALDL, and insert the other end into the top row second from the right. You'll have the paperclip bent in a "U" and the two upper right ports jumped together. Now turn the key ON ignition OFF. You'll hear the fans come on and the SES light will start flashing:
Flash Pause Flash Flash Long Pause and repeat two more times. This is DTC 12 showing that the computer is in diagnostic mode. After it flashes DTC 12 three times, it will start flashing any stored codes in the same configuration. I.E. DTC 36 would be:
Flash Flash Flash Pause Flash Flash Flash Flash Flash Flash Long Pause three times.
Write down any codes that come up. Once all the codes have been flashed, the computer will continually flash DTC 12. At this point you can turn the Key OFF and remove the paperclip, and you're done.
DON'T rely on a chiltons/haynes manual for correct 93 DTC descriptions. They're a conglomeration of sorts of 93's and 94-95's. This Link has all of the 93 DTC's (including diagnostic charts) scanned directly from a GM service manual.
Old Jan 6, 2005 | 05:54 AM
Joe Bellman's Avatar
Fastbird93, check that link. I can't get it to open.
Old Jan 6, 2005 | 05:21 PM
Fastbird93's Avatar
Hmmm.....works good for me.
Old Jan 6, 2005 | 07:42 PM
Works here too.
-Dustin-
Old Jan 6, 2005 | 08:07 PM
it is now working for me. Must have been the computer system at work blocking it for some reason.
Old Jan 8, 2005 | 12:01 AM
Got-LT1's Avatar
thanks all, I'll have to wait to try it, the cars at school and I'm stuck here for a for more days....
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
