is this the right angle on the hone job??
Old Jan 7, 2005 | 05:01 PM
marshall93z's Avatar
just curious...i was thinking it is supposed to be like 30 degrees or so.
nevermind the stuff that looks like rust on the deck...its a mixture of the liquid i used and a little rust from the cylinder.
http://img11.exs.cx/img11/2872/hone8se.jpg
Old Jan 7, 2005 | 05:57 PM
captaindbol's Avatar
Re: is this the right angle on the hone job??
The hone looks like it should seat your rings just fine, but I still see a ridge at the top of the bore. Have you miked the bore and checked for taper with a dial gauge? If your trying to reuse stock parts on a stock/driver rebuild I understand, but if not a bore and hone is pretty cheap if your buying new parts anyway.
Old Jan 7, 2005 | 06:16 PM
yeah, reusing stock parts on a driver. should i remove the ridge from the top. i plan to mic the walls in the next couple of days to make sure its all ok.
Old Jan 7, 2005 | 09:19 PM
pm sent
Old Jan 8, 2005 | 12:12 AM
got it...thanks!
92rslt1's Avatar
not too bad ...what did you hone it with??
IndyZman
Oct 22, 2015 02:17 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
