scanned my 94 code help please
Old Apr 7, 2009 | 06:21 PM
wsuggs's Avatar
Well I scanned my car and I'm getting code 26 and 27 the car is acting funny stumbling liike crazy with some spark knock. Would these codes cause that or should i investigate further i've logged freescan and datamaster but don't know how to attach the logs. any help would be appreciated
Old Apr 7, 2009 | 06:29 PM
5.7orNOTHING's Avatar
I believe the code 26 is for a QDM fault, which is inside the ECM
Code 27- EGR vacuum control solenoid circuit
Old Apr 7, 2009 | 06:34 PM
Chevyguy358's Avatar
opps nevermind, guy above posted
Old Apr 7, 2009 | 06:58 PM
94_PatriotRed_Z's Avatar
26 is Evaporative Emission (EVAP) canister purge solenoid valve circuit
27 is Exhaust Gas Recirculation (EGR) vacuum control signal solenoid valve circuit
Here is a full listing of CODES from Shoebox's website.
He doesn't have a 1993. No QDM faults on a 1994.
26 Evaporative Emission (EVAP) canister purge solenoid valve circuit
27 Exhaust Gas Recirculation (EGR) vacuum control signal solenoid valve circuit
Since you have 2 faults for solenoids, I would check fuses first.
Old Apr 7, 2009 | 06:59 PM
But not a completely correct answer. You have to use the correct list for the LT1. Shoebox has it on his site. 93 was the last year that the ECM included the quad driver modules. In 94/95 DTC 26 is for the EVAP purge solenoid.
http://shbox.com/1/Dtcs.htm
Check the harness connectors for both solenoids, assuming you still have them connected. They also share a common fuse.
Old Apr 7, 2009 | 07:03 PM
wsuggs's Avatar
Would my factory manual lead me to the right codes? Or does anyone know which fuses to check off the top of their head. Also would the egr falt be causing the ratty running?
Old Apr 7, 2009 | 07:16 PM
If you have a factory service manual, you have everything you need to troubleshoot (info-wise).
Old Apr 7, 2009 | 10:15 PM
The EGR fault is for the electrical circuit to the EGR vacuum solenoid. It isn't likely that would be the problem, unless the solenoid is shorted to ground, and is staying fully open all the time. Pull the harness connector off the solenoid, and see if it affects the way the engine runs. It wouldn't idle well at all if the EGR system was "on" at idle.... probably just stall.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
