scanmaster reading code 70????
Old May 28, 2006 | 03:04 PM
detroit1994z28's Avatar
My scanmaster just recently put a code 70 under the dtc mode. Does anyone know what this code is?? I been trying to find it in the manual but there's no such code as a 70. The car was reading code 21 - I replaced the tp sensor and 15 minutes of driving the 70 code appeared - Need help?
Old May 28, 2006 | 03:51 PM
Re: scanmaster reading code 70????
70 A/C clutch relay driver circuit
You can find a list of codes here.
Did you happen to disturb any other wiring while changing the TPS?
Old May 28, 2006 | 04:03 PM
Hey thanks buddy. I been looking for this code for over 2 hours. Thanks again dude. - I appreciate it - Mike
Old May 29, 2006 | 01:10 AM
The code is also listed in my online ScanMaster manual......
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old May 29, 2006 | 08:27 AM
- A/C clutch relay driver is the problem. Is that the ac relay in the fuse box??? I tested the one in my car and it's working. If that's not it then where is this relay located exactly. The book shows this as a ac compressor relay --- that's what I check - turned out to be good.
Old May 29, 2006 | 08:33 AM
Dave89IROC's Avatar
the "relay driver" is the signal wire that the PCM uses to trigger that relay
Old May 29, 2006 | 11:07 AM
So you think it might be a bad wire or something. Do you know what color that wire is by anychance?
Old May 29, 2006 | 11:13 AM
Dave89IROC's Avatar
yes, might be a wire,
dark green with a white tracer, from pin 8, connector D(blue) at the PCM
Old May 29, 2006 | 11:25 AM
Thanks - Mike
Peytons'z
May 6, 2021 09:25 AM
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
