Scanmaster and LT1 Edit
Old Jun 23, 2003 | 12:25 PM
SSkindog's Avatar
I want to be able to read codes and dynamic info from sensors, and be able to reprogram the PCM, based on mods and such.
1994 Z/28
It appears as if I need Scanmaster, and LT1 Edit together in order to accomplish this? And any cabling?
Could someone verify this for me, and point me in the right direction as far as where to buy?
Joel
Old Jun 23, 2003 | 01:21 PM
You only need LT1_Edit for OBD-I. It comes with bundled scan software (PCMCOMM). There is an upcharge for making the scan software into a data logger.
Or download "FreeScan" (guess how much that costs ), or dowload TTS DataMaster for free and use it for 20 times before you need to license it. Cable from Andrew at AKM Cables.
Hardware wise, you can get the ScanMaster, AutoXray, or Actron sells a scanner (not the $30 paper clip in a box type).
thenewkid
Nov 29, 2014 04:54 PM
snksknr94
Aug 2, 2002 07:31 PM
Bando
Aug 2, 2002 02:18 PM
