Scanmaster Code 66 question
I have a 93 Z28 with a 95 LT1 engine. I removed the AC about 3 years ago and had the PCM programed to reflect the change by PCM4Less.
Recently I started to receive a Code 66 (A/C refrigerant pressure sensor circuit (open or shorted)), is there anything that I can do to get this code to go away, I know its nothing major, just an annoyonce.
My second question, are the fans from a 93 compatible with a 95 engine. I have noticed recently that they stay on all the time. The car is not running hot and infact runs great. Could this be tied to the Code 66 I am receiving??
Thanks in advance
Thanks in advance
Thats what I call service
Thanks for the quick response. I do have an open connection, however I have checked the wiring and nothing is cut or broken, just an open connection. How would you go about closing that off?
Again, thank you for the response
The 93-early 94's used a system of two relays to turn the fans on one at a time. The late 94 and newer models used a system of 3 relays to operate both fans at low and high speeds.
Thanks Injuneer! Through the years ( you may not remember me) you've been a great help, along with other members of the forum.
Just wanted to say Thanks.
So I guess my couse of action should be to upgrade to the correct fans
Thanks agian!
Thanks agian!
Jul 4, 2005 05:00 PM
