scanmaster
Old Feb 24, 2003 | 01:43 PM
sweetblue's Avatar
scanmaster
I just got one of these and was wondering will it screw with the hypertech programming or anything.
Old Feb 24, 2003 | 01:46 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: scanmaster
nope
they are mutually exclusive systems
check brents site for help with it
Old Feb 24, 2003 | 02:17 PM
sweetblue's Avatar
thanks much
Old Feb 24, 2003 | 02:37 PM
95_RipperZ's Avatar
The site is www.bfranker.badz28.com
Old Feb 24, 2003 | 02:45 PM
If you install the ScanMaster, you will have to disconnect it when you attach any other device, such as the HPP+. There is two-way communication between the ScanMaster and the PCM, so it will interfere with a programmer or another scan device. I wired my ScanMaster permanently, then put a switch on the data wire, to allow it to be disconnected when the programmer is hooked up.
Old Feb 24, 2003 | 09:12 PM
Brent94Z's Avatar
Super Moderator
Just to add some clarification... like Fred said, you'll need to put a switch on your ScanMaster for anytime you want to connect something else to the ALDL port. But, this doesn't mean it won't work with the HPP+. Once you finish the uploading from the HPP+ it'll work fine... they just won't work together at the same time (don't turn on the ScanMaster while programming with the HPP+!!!).
Old Feb 24, 2003 | 09:19 PM
treyZ28's Avatar
ohh yea
i thought you meant will it scan correctly after i used Hypertech
Old Feb 24, 2003 | 09:22 PM
turbo_Z's Avatar
an easier method than splicing into wires is to buy a connector so you can simply unplug the scanmaster. Andrew at www.akmcables.com sells these for $10.
Old Feb 24, 2003 | 10:22 PM
Z28ROC's Avatar
I hooked mine up using Brent's guide. And put a mini toggle like Fred was talking about. Works just fine.
Peytons'z
May 6, 2021 09:25 AM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
Shon Herron
Mar 18, 2003 12:18 PM
88irocz28
Feb 28, 2003 11:24 PM
