ScanMaster
Old Nov 6, 2007 | 03:08 PM
96supersport's Avatar
ScanMaster
i tried searching for it....
where can i buy one, and how much do they run?
Old Nov 6, 2007 | 03:32 PM
wrd1972's Avatar
http://www.thunderracing.com/catalog...vid=4&pcid=152
Check the for sale board too, thats where I bought mine.
Old Nov 6, 2007 | 03:33 PM
Green96Z's Avatar
New Era Performance Parts has em. $250 each.
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=050SCANLT1|0
Old Nov 7, 2007 | 12:54 AM
porksoda's Avatar
Would this be a better investment than a wideband? I plan on spraying by next year.
Old Nov 7, 2007 | 07:45 AM
01Z's Avatar
01Z
FullThrottleSpeed not only sells them, that's where they are made.
Aeroforce makes the Interceptor II - a round 2 1/16" gauge that is at least the equivalent and will go nicely into an A-pillar pod. I wish I had known about it before I bought my 2nd ScanMaster.
The scan gauge compliments a wideband kit. I would shoot for the scanmaster first and add the WB when you can afford it. I do have both and that's why I recommend that....
Old Nov 7, 2007 | 09:45 AM
OBE1 95Z28's Avatar
The ScanMaster lets you display the data the PCM data, one parameter at a time; for O2 readings, it will display the stock narrow O2 readings. This is completely different then a wideband O2 sensor and its readings.
Peytons'z
May 6, 2021 09:25 AM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
Shon Herron
Mar 18, 2003 12:18 PM
88irocz28
Feb 28, 2003 11:24 PM
