Using 96 Opti on a 95...
Old Nov 5, 2007 | 11:25 PM
B-Rad420's Avatar
I just picked up a 96 LT1 for my 95 T/A and I have heard that the opti's might be a lil' different in 96. I also heard the crank hub is different. Will I have any problems installing this motor in my T/A. As of right now I am transfering the heads and cam from my current engine to this new one but I do not have an Opti and was planning on using the one that came with the junk yard 96 lt1. Thanks, Brad
Old Nov 5, 2007 | 11:28 PM
Stl94LT1's Avatar
95/96 opti's are the same.
Old Nov 6, 2007 | 12:58 AM
emerica4601's Avatar
yep, its the 92-94 ones that are different (yes there was an lt1 in 92, the vette)
Old Nov 6, 2007 | 01:16 AM
B-Rad420's Avatar
But they do have a different timing cover that I wont be able to use correct?
Old Nov 6, 2007 | 06:46 AM
Use your 1995 timing cover, crank hub and knock sensor.
Old Nov 6, 2007 | 11:41 AM
B-Rad420's Avatar
Shoebox, you are awesome. I am about to read your heads and cam swap article because as of right now I dont know exactly how to put my coyees timing chain on or set valve lash.
Old Nov 7, 2007 | 09:49 AM
OBE1 95Z28's Avatar
In 1996 OBDII included a crank position sensor. This sensor is mounted in the timing chain cover and requires a reluctor "gear" to be added to the crank snout. The crank hub was shortened to allow room for the reluctor gear.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
