Scan Tools
Old Mar 4, 2006 | 10:20 PM
96 trans am's Avatar
Question Scan Tools
Hey guys, what are some good scan tools? I've heard of AUTOXRAY 6000, anyone heard of that? What else is good for the OBD-II? I have a 96 ta if that helps. Thanks guys.
Old Mar 4, 2006 | 10:35 PM
jay_lt4's Avatar
Re: Scan Tools
www.autoenginuity.com
Old Mar 5, 2006 | 09:06 PM
EviLBoX's Avatar
Re: Scan Tools
If you have a laptop I'd recommend this -> http://www.obd-2.com/ I've been using it for several years and now and it has been great.
Old Mar 5, 2006 | 10:39 PM
hotrod18_69's Avatar
Re: Scan Tools
I've got a GM Tech II. I love it.. And soo do all of my friends..
I've never used anything else on the market yet..
Old Mar 6, 2006 | 11:15 PM
Dan Parker '96's Avatar
Re: Scan Tools
http://www.obd-2.com or http://www.efilive.com
OBD-2 will scan just about anything (any manufacturer, any engine) from '96 on and can log every possible parameter. It just isn't real pretty from a graphical standpoint. You can use it on any car.
EFILive (version 5) will log all the standard SAE functions for the LT1 but is really geared for the LS1 and later. You can program it so it will find the LT1 specific stuff but it takes some effort. It does, however, graph the functions beautifully so they are very easy to see.
I use both. OBD-2 for the really specific LT1 stuff and EFILive for the general SAE items.
Old Mar 13, 2006 | 05:11 PM
Re: Scan Tools
Do I need this, when I purchase the scanner from http://www.obd-2.com?
Everyday shop use, integral car connector (Trican, Tricom and iMax models) -- 75 Watt 110 Volt AC car lighter plug $22
Universal USB to serial port adapter, if laptop has no rs232 male 9 pin serial com. port (no support for single ISO or iMAx) $20
Old Mar 13, 2006 | 05:13 PM
Re: Scan Tools
Or this?
No -- 25 ft $12 -- 50 ft $22 -- 100 ft $32 -- 16 pin male/female to rj45 extension adapter, required for 100 ft Tricom,
Old Mar 15, 2006 | 10:53 PM
Re: Scan Tools
Just e-mail the guy and tell him your situation. He'll let you know what you need.
I ordered mine several years ago and got the "reads everything" combination at the time. His selection has increased a bit from then. But pricewise, you can't beat his stuff.
marlar98
Sep 12, 2018 07:18 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
