scan question
Old Oct 11, 2006 | 11:49 PM
86gn01's Avatar
scan question
Just wondering is 6375 the max rpms data master or other scan software can record up to? have a 95lt1 (built 383 ) can push it further then 6375 rpms but datamaster stops recording @ that rpm.
Old Oct 12, 2006 | 10:07 AM
Re: scan question
They may be using a single 8-bit binary field in the scan software. RPM is measured by the stock PCM in 25rpm increments, so 25 x 255 = 6375 is the upper limit of an 8-bit field. The stock PCM must use additional bits internally to allow it to operate in exces of 6375rpm.
dluna333
15
Mar 13, 2015 12:30 PM
aj2494
Mar 12, 2015 10:17 PM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
Brent94Z
Mar 21, 2002 04:44 PM
