Hotcam install
Old Oct 10, 2006 | 12:50 PM
97formulakid's Avatar
Hotcam install
I have recently got 2 bonus' from my work and with the extra money am thinking about doing a Hotcam kit. Before any of you start to dog the Hotcam telling me to get a 224/230 or cc305/306, I decided to go with the Hotcam because of the price. I am looking at something cheap and can make decent power. I know there are probably better cams out there, but the Hotcam just seems like what I want, the car is very streetable right now and I don't want to compromise that or spend a ton of money to put a cam in. I am also thinking about cleaning up the heads some and porting the intake of the car.
So, what pushrods, lifters, and guideplates should I use with the hotcam???
Also, since I plan and doing a mild port job on the heads and intake, should I get a bigger TB and injectors???
Thanks guys!!
Old Oct 10, 2006 | 01:29 PM
bingo's Avatar
Re: Hotcam install
When I put the hotcam kit in my car I used all my old stuff. Stock pushrods, lifters, no guideplates. I did use the matching springs that came in the kit. Mine ran fine until some bottom end trouble developed. I liked mine and it was a good deal for the price.
Old Oct 10, 2006 | 03:12 PM
Re: Hotcam install
my car has over 100,000 miles on it. I was going to go ahead and replace the pushrods since I can get a good cheap set for about 40 bucks. The lifters are 240-300 for the set so I might go ahead and reuse the stock ones.
Any other input?
Old Oct 10, 2006 | 10:51 PM
knta4dnu's Avatar
Re: Hotcam install
Stock throttle body will be fine. Porting the intake isn't necessary, but gasket matching everything is a good idea. If you have to choose, replace the lifters before the injectors. Much easier to change/upgrade the injectors at a later date, and the stockers can handle the cam.
New timing chain is a good idea. Again, a stock piece will be fine.
LT4 Knock Module and computer retune are a must.
If you can, new wires, at least opti cap and rotor, O2 sensors. All so much easier to do while it's apart anyway.
I'm happy with the Hotcam Kit, especially since I had the 4.10's put in, because it makes it's power at a bit higher RPM than the stock cam.
Old Oct 11, 2006 | 08:42 AM
Re: Hotcam install
Already have new wires, o2 sensors. I could probably do a new opti. I will most likely go with the Coyles Double Roller since I have an electric WP.
Old Oct 11, 2006 | 09:08 AM
95mysticta's Avatar
Re: Hotcam install
i just picked up the cam last week off a buddy of mine with the spring kit. I have a lead on a spring set and pushrods from comp cams that ill be using instead for a bit more durability. I was looking at a cam for the sound quality... power is always good but i wanted the nice lopey idle. My next choice was the CC305 so i can stil retain emissions and streetability. My next thing to buy will be a set of cc magnum 1.6rr. Everything else im going to keep the originals with. Lifters and the timing chain should do for the use i give it. People that ive been having talks with say that there not nessessary and havent had any problems so far with a couple years of use under there belt
Let us know how your build goes dude and some audio clips to would be sweet. good luck!
Old Oct 11, 2006 | 09:57 AM
16Z's Avatar
16Z
Re: Hotcam install
the kit and gaskets are all you need
just make sure there isn't any wear on the lifters
stock TB and injectors will hold up fine
might be a good time for a Cap/rotor change tho
also i ported the intake a few weeks ago and it did seem to make a diffrence
i almost wish i got a CC306 but then again a lightly moded 98 ls1 only got me by 3 cars from a roll (with a failing opti)
Old Oct 11, 2006 | 10:46 AM
GhostZ's Avatar
Re: Hotcam install
I used the springs that came with the kit as well but started getting some float on the top end a few months after install. I had a set of heads/intake that I was getting worked along with a bigger cam so I didn't mind the float since I swapped over soon after.
Good cam....great for the price of the kit, that dropped me down to a 13.2 at 7000 DA (had TC, full exhaust, CAI and gears as well at the time).
Old Oct 11, 2006 | 11:21 AM
pj97ragtop's Avatar
Thumbs up Re: Hotcam install
I have the lt4 kit from summit and long tubes from jet hot it runs good haven't been to the track yet it rains every wed. this is in a 97ss ragtop
Old Oct 11, 2006 | 12:28 PM
MeanGreen97Z's Avatar
Re: Hotcam install
My LT4 Hot cam was great! After the install I still got pretty good gas mileage. Cam makes good power and with the right bolt ons the car will scream!
Old Oct 11, 2006 | 05:46 PM
Re: Hotcam install
Well last night I saw a 94 Z with just the hotcam and LT's beat a 00 T/A with FlowPac and Exhaust by about 2-3 cars. I couldn't believe my eyes. I thought he was spraying but afterwards we looked at his car and I even talked to the guy who put the cam in and that is all they did to it. I can't wait to get the cam!!! Especially with the juice!!
Old Oct 11, 2006 | 06:14 PM
Re: Hotcam install
The hot cam is a great nitrous cam! I loved the juice on that cam.
Old Oct 12, 2006 | 10:14 AM
95mysticta's Avatar
Re: Hotcam install
does anyone here have any audio clips? i have lts and cai on the car now just wondering what it will sound like with cam afterwards come next spring
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
