same question over and over
Old May 18, 2005 | 01:44 PM
TRIPOWER's Avatar
just picked up a 97 lt1 and i want to build the motor but i live in the chicago area and i have to deal with emissions. so my question is i want to put in a hot cam, long tube and just the normal bolt on's will i have a problem with epa?
Old May 18, 2005 | 02:10 PM
BUBBA's Avatar
Re: same question over and over
Hot Cam, ok, but LTs maybe not. You probably have dual cats and perhps it would not be allowed to change the position the cats, which would be necessary in order to install long tubes. JMHO
Old May 18, 2005 | 02:13 PM
CustomSSI's Avatar
Do you know do you have to pass a sniffer test and a visual or just sniffer? if just the sniffer you should be fine relocating your 02's and cats with LT's.
Josh
Old May 18, 2005 | 02:36 PM
TRIPOWER's Avatar
i think its just a sniffer test, and i will try running high flow cats on the car. also can anyone tell me the who makes the opti-spark repalcement coil kit? someone was telling me about coil kit is this true?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
