safety when turning motor over by hand
I need to manually turn the engine over a few times to check things such as exact pushrod length via the expo marker test and a couple other things
however, I would rather not disconnect the battery if I do not have to because I have already put 40 miles on the PCM since the LE1 swap and the car has gone through a good deal of learning.
Is it safe to turn the motor over by hand as long as the key isnt in the ignition, or is there a chance it might fire up and break stuff and my arm
The computer relearns the fuel trims very quickly after being disconnected. Also, a good tune should not be very far of the corrected values once the computer has "learned" the car..
If I disconnected your battery now to reset the computer and hooked it back up (without u knowing it) you probably wouldn't even notice a difference. And if you did notice a difference it would probably go away before the engine is fully warmed up
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
formula79
26
Aug 5, 2002 12:21 PM
