Safe to switch to synthetic
Old Mar 27, 2004 | 06:08 PM
badazzcamaro97's Avatar
My car has 88,000 miles on it, and it only leaks a very small amount between oil changes, not enough to show on the dipstick.Would it be safe to switch to Mobil 1, or might this make the leak worse?
Old Mar 27, 2004 | 06:13 PM
sabre81's Avatar
safe? yes, will it leak more? maybe. Why not fix the leak? its probably the inatake manifold at that mileage
Old Mar 27, 2004 | 06:20 PM
Thanks for the replies, would be the intake leaking if the oil shows up on the front cover of the tranny
Old Mar 27, 2004 | 06:23 PM
94_formula's Avatar
front of the tranny?? you mean the bellhousing? that would be your typical rear intake leak on the lt1
Old Mar 27, 2004 | 06:46 PM
Yeah thats what I was talking about, my mind went blank couldnt think of the word
Old Mar 28, 2004 | 06:01 AM
Patman's Avatar
Definitely safe to switch, but if you're going with Mobil 1, I'd highly recommend their 0w40 over their 5w30 or 10w30.
Old Mar 28, 2004 | 06:23 AM
scoobysnax83's Avatar
Originally posted by Patman
Definitely safe to switch, but if you're going with Mobil 1, I'd highly recommend their 0w40.
thats what I use
Old Mar 28, 2004 | 08:16 AM
wicked_95z's Avatar
Your leak could also be coming form the front main seal and blowing back when you are driving. Just a thought. When my front main was leaking I was getting oil as far back as my rearend
Old Mar 28, 2004 | 09:43 AM
T/A#4's Avatar
Re: Safe to switch to synthetic
For the inside scoop go to; mobil1.com
Old Mar 28, 2004 | 12:43 PM
Patman's Avatar
Re: Re: Safe to switch to synthetic
Or even better, go to www.bobistheoilguy.com, and then check out the message board there too.
Old Mar 28, 2004 | 12:47 PM
Scream And Fly's Avatar
My car started leaking after I went to synthetic oil, but I don't care - the extra protection is worth it, and my LT1 has over 100K miles, so I can't complain about a small drip here and there.
Greg
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
