safe to break in motor without tune?
Old Jan 19, 2009 | 02:24 PM
  #16
sn8ke eatr's Avatar
ok thanks guys i get it. ill probably trailer it there since it would save me a trip anyway and the hassle of 2 tunes..
now can i buy a 94-95 pcm and plug it directly in, or is there more to it then that?
Old Jan 19, 2009 | 03:18 PM
  #17
Stl94LT1's Avatar
Unfortunately, it's not that easy.
Old Jan 19, 2009 | 03:41 PM
  #18
sn8ke eatr's Avatar
i figured haha
Old Feb 12, 2009 | 11:17 PM
  #19
CreatiVe2's Avatar
sorry to hijack this thread, but i am kind of in the same situation, might be able to add to the thread. I have a 383 that i just broke in with a base tune with my 32 lb injectors. i will be getting 42 lb injectors in a about a week. would it be safe to run the car tuned to 32 with the 42's? i don't want to do it, and will get a re tune if necessary, just wondering what serious damage could occur? rings get washed out?
Old Feb 13, 2009 | 12:16 AM
  #20
user 647483's Avatar
If you run 42s on a tune designed for 32s, you're going to end up with a lot of extra fuel in there.
It'll run rich, the piston walls will be stripped of lubricant and you'll likely contaminate/dilute the oil with excess fuel.
Why would you want to do that?
You can change injectors easily once you reach the dyno facility and avoid the problem alltogether.
Seriously ... do you really want to run your car on the dyno with diluted oil?
Old Feb 13, 2009 | 07:45 AM
  #21
CreatiVe2's Avatar
hah no, and i figured that'd be the case. i have to send my injectors out to be reworked. unless i find that 32lb/hr injectors will be fine for <450 Rwhp :/
they will be getting reworked to 42 lb/hr
Old Feb 13, 2009 | 08:12 AM
  #22
Gonna need at least 36s, more likely 42s.
Might as well do it right the first time.
Old Feb 13, 2009 | 08:46 AM
  #23
CreatiVe2's Avatar
yeah, the design III that bosch makes are only jetted to 32 lb/hr, im sending them over to www.fuelinjectorconnection.com to have them redone to 42 lb hr.
They didnt have this when i bought mine.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
