safe to break in motor without tune?
Old Jan 16, 2009 | 05:20 PM
sn8ke eatr's Avatar
well ive got a 383, 11:1, le2's, big HR cam, etc and i am wondering if it will be safe to run my car at all without a tune ( 15 mile trip to tuner) also, i have a pcmforless mail order tune for a full bolt on/cam only car. would it be smarter to put that in, or leave it as stock
Old Jan 16, 2009 | 07:30 PM
bombebomb's Avatar
If you run that without a tune, not only will it refuse to idle, but it will run extremely rich (which can wash out the rings). I would personally trailer it there.
No idea on the mail order tune that you have.
One would think a "kinda close" tune is better than a "clear out of wack" tune. But I do not know.
Old Jan 17, 2009 | 04:46 PM
sn8ke eatr's Avatar
i know man im thinking the same thing. like logically it makes sense that it would run closer to good on the other tune but i know if i do, something will blow up, then when i post it, everyone will be like wtf why would you do that you dumbass lmao
Old Jan 17, 2009 | 05:11 PM
Stl94LT1's Avatar
What size injectors, and were they in for the mail order tune?
Old Jan 17, 2009 | 05:30 PM
bombebomb's Avatar
Why not trailer it there?
Old Jan 17, 2009 | 07:25 PM
sbs's Avatar
sbs
Get your tuner to give you a base tune that is close enough to drive at part throttle to his shop.
He ought to be able to guesstimate within 25% and would be doing that as a first step anyway...
Old Jan 18, 2009 | 05:49 PM
sn8ke eatr's Avatar
stl- the tune is for stockers, i now have svo 30's
bomb- i can.. id just save the 55 bucks for the uhaul trailer by driving it ( im poor $55 is a considerable amount of cash for me at this point lol)
steve- can you do that for a 93?
Old Jan 18, 2009 | 07:10 PM
Daniel6718's Avatar
get a base tune...or at least run the same injectors its runed for..i always get a base tune though....its dumb not to..
Old Jan 18, 2009 | 07:54 PM
Stl94LT1's Avatar
If it's at least not tuned for the 30's, I wouldn't drive it. Or, you could drive it to the shop with the stock injectors and switch them out when you get there. Too bad it's not a 94/95 I would send you a starter tune.
sbs's Avatar
sbs
Not sure exactly what that means - but if you mean "can I do that at home" I'd say just take the PCM to your tuner to install the baseline tune.
Old Jan 18, 2009 | 08:19 PM
user 647483's Avatar
Exactly, have something somewhat safe to start with.
Depending on the size of the cam, it may be tough to tune it remotely and your only choice may be to trailer it.
I'm in that boat right now, but my cam has 34* of overlap LOL so it's a
little tougher to tune than your typical HR street cam.
I'll be trailering mine from KC to Tulsa in a few weeks.
The base tune was simply too rich to drive (less vacuum than expected).
$55 for a trailer is a hell of a lot cheaper than ruining a new 383.
Old Jan 18, 2009 | 09:29 PM
sn8ke eatr's Avatar
thank you guys for helpin first off,
what i mean by that is my cars a 93, its obd1 and i was under the impression you cant flash my pcm like the latter models
so what your saying is bring the pcm itself to the tuner and he will be able to give it a base retune just to get the car to the shop? im sorry if im soundin dumb here i was just under the impression that to tune an obd1 car you had to install a modified "chip" which is like what i have now, the mail order "chip" sitting in my room. i didnt think you could just wipe out a tune and form a new one like on the obd2 cars
james- i totally get what your saying, $55 is chump change when you melt down a forged 383 and yea i wish it was a 94/95 because i know u can just reflash em and i appreciate u offering yours to me
Old Jan 19, 2009 | 01:15 AM
bombebomb's Avatar
You're car needs a chip. Also 94-95 is also OBD1 but you can "retune" the pcm without a chip (just so you know).
I was under the impression (for whatever reason) that you could get a trailer (or barrow) from someone for free. Since you can't, I see why this is a concern.
Old Jan 19, 2009 | 01:56 AM
sbs's Avatar
sbs
yes.
Old Jan 19, 2009 | 09:57 AM
Stl94LT1's Avatar
No need to take your PCM to the tuner for a start-up tune, he can simply send you another eprom/chip.
