SA or NSA rockers??
Old Feb 28, 2007 | 07:44 PM
arklie's Avatar
SA or NSA rockers??
My short term plan is 1.6 rr's with new springs. My long term goal is a bigger cam. Should I go with NSA rocker's or SA rockers. I've heard that NSA is more stable at high rpms. Is it really worth the effort of having to get guideplates and hardened pushrods? Thanks.
Old Feb 28, 2007 | 08:07 PM
2000GTP's Avatar
It also depends on what grind of cam you go with. If you go with a tamer cam, you can still get away with SA rocker arms. If you plan to go with something like the CC503, CC306, or beyond, I would do the NSA setup.
Old Feb 28, 2007 | 08:25 PM
SS RRR's Avatar
It's cheap insurance to have guide plates. Neither hardened pushrods or guideplates are expensive.
Old Feb 28, 2007 | 08:34 PM
The Engineer's Avatar
If you're not going to turn more than about 6500 RPM, the SA's will work OK. However, if you will be turning 7000+ RPM you should use the NSA's with guide plates.
WD
Old Feb 28, 2007 | 10:02 PM
69z-28's Avatar
would SA's be fine with a 503 cam, stock heads and planned redline of around 6k?
Old Mar 1, 2007 | 11:28 AM
Z-RATED94's Avatar
Don't limit the cam to what kind of RPM your happy with. If that's the case, go with a cam that peaks earlier so you have all the benefits of said cam. As in if the cam peaks at 5700 your shift points would be around 6000.
Old Mar 1, 2007 | 03:19 PM
slp97camaro's Avatar
sorry for kinda high jacking your thread...but would it be okay to run SA 1.6rr's w/ a gm847 cam? ill be shifting around 6300-6500
Old Mar 1, 2007 | 04:14 PM
69gto96z's Avatar
I would do NSA. Might cost a little bit more now, but if you want to upgrade to a bigger cam and rev higher later on and you go with SA now, then you are buying another set.
Old Mar 1, 2007 | 04:16 PM
2000GTP's Avatar
I agree, with that kind of cam, I wouldn't go cheap on the supporting valvetrain parts. I would use NSA rockers.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
