?s about welding relocation brackets
Old Aug 27, 2003 | 07:08 AM
PatriotTA's Avatar
First, should I disconnect the PCM? If so, what is the best way to do so to protect it while the car is being welded on? Also, did those of you that welded your own brackets have to remove any brake line or anything else back there, or where you able to move stuff and shield it? Does anyone have any decent pics of the finished product?
Old Aug 27, 2003 | 10:16 AM
LPEdave's Avatar
Disconnect your battery when welding, that'll protect the pcm.
I had mine done at a local Midas, and no brake lines were disconnected. Some pics at http://www.go-fast.org/z28/suspension.html
Dave
Old Aug 27, 2003 | 10:40 AM
Always pull the positive battery connector when welding. To minimize stray currents, try and attach the ground clip as close to the weld point as possible.
I watched Steve Spohn weld in my relocator brackets, and he didn't have to remove anything. Took a few minutes on each side.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
War Engine
Sep 18, 2015 07:28 PM
Boss002
Jul 24, 2015 10:47 AM
