RWHP vs. flywheel
Old Dec 1, 2004 | 11:13 AM
  #16
turbo_Z's Avatar
Re: RWHP vs. flywheel
I was told it was 16% at the dyno. Seemed a bit high but I didnt question the man because really I could care less what the FWHP is.
Old Dec 1, 2004 | 12:12 PM
  #17
Originally Posted by 1racerdude
Man--- that sounds like a big gain(or loss) for a stick--figuring it at 16%.Thats more like an auto with a converter and a 9".16% must be way high. The 10-12% sounds more reasonable to me but I have not dynoed every car on the planet,just a few.
Dude... I am NOT..... repeat NOT.... NOT saying the losses are 16% for a "stick". I've already explained that I believe, based on actual measurements, that its in the range of 12-13%. I was only using the 16% to match the numbers "97bowtie" used so that he could understand why what he said was wrong.
Another thing to remember..... the drivetrain losses are based on inertia losses (do not vary with flywheel HP) and friction losses (vary proportional to flywheel HP). Hence, it is NOT a fixed percentage, but a variable one. I found it ranged from 12.6% at 500flywheel, to 12.2% at 800flywheel in the dyno test on the engine. The losses on a stock engine will be a larger percent than they will be on a 500HP engine.
Old Dec 1, 2004 | 01:02 PM
  #18
stereomandan's Avatar
I totally agree with you there. It's the power that you put to the ground that matters.
Dan
Old Dec 1, 2004 | 01:05 PM
  #19
97bowtie's Avatar
Originally Posted by Injuneer
No they aren't, and no you can't. If you accept that the losses are 16%, you can either divide rwHP by 0.84 [1.00 - 0.16 = 0.84], or you can multiply rwHP by 1.1905 [ = 1 / (1.00 - 0.16) = 1 / 0.84 = 1.1905].
414 / 0.84 = 493 flywheel
414 X 1.1905 = 493 flywheel
I dunno what I was thinking...I guess Calc 2 diluted my recollection of the basics. That's terrible.
Formula Steve
Sep 19, 2023 08:31 AM
95chwagon
Oct 16, 2015 12:24 PM
karpetcm
Sep 29, 2015 10:08 AM
Z Power
Sep 19, 2015 11:19 PM
Bxlt1
Sep 17, 2015 08:31 AM
