RWHP To Expect
Old Oct 23, 2005 | 05:33 PM
93 4mula's Avatar
RWHP To Expect
Just curious what rwhp yall think I will be putting down on my new motor.
"383"
12.6:1 CR
Eagle Forged 4340 3.75 Stroke
Eagle H Beams 5.7 Length
SRP Forged Flat Tops -5cc 4.030 bore
LE3 Heads
42lb Injectors
BBK 58mm
Crane Cam 240/244 .595/.595
Magnum 1.6rr's
Comp R Lifters
Pacesetter LT's
Summit X Pipe Kit 3inch
Spec Alum Flywhl
Spec Stage 3 clutch
Cloyes Double Roller
Old Oct 23, 2005 | 05:36 PM
Jameslt1TA's Avatar
Re: RWHP To Expect
425 rwhp.
JustNO's Avatar
Re: RWHP To Expect
450rwhp+
Old Oct 23, 2005 | 05:50 PM
SStrokerAce's Avatar
Re: RWHP To Expect
413rwhp with a peak around 5900-6000rpm based on the cubes, valve lift and valve size. That's if you get 100% VE at 6000rpm.
Bret
Old Oct 23, 2005 | 05:51 PM
Jameslt1TA's Avatar
Re: RWHP To Expect
Originally Posted by JustNO
450rwhp+
Maybe with a custom cam, ported intake and dead on tune. But i could be wrong.
Old Oct 23, 2005 | 07:07 PM
Turbo6's Avatar
Re: RWHP To Expect
435rwhp/409rwtq
Old Oct 24, 2005 | 06:50 AM
calfirebird's Avatar
Re: RWHP To Expect
well i have Le2 heads and a tiny bit smaller cam and made 417 with an auto. So my guess is around 435rwhp about 6200
Old Oct 24, 2005 | 07:08 AM
JustNO's Avatar
Re: RWHP To Expect
Bret
So you say ~485hp at flywheel with %15 drivetrain loss?? He can't see 500hp ha??
Old Oct 24, 2005 | 12:02 PM
Re: RWHP To Expect
Basically. One reason why I don't feel that cubes nessesitate more duration is because the valves will choke off the heads pretty quickly and more duration is just going to kill some of that extra TQ that you are trying to make with the extra cubes.
Bret
Old Oct 24, 2005 | 12:35 PM
JustNO's Avatar
Re: RWHP To Expect
Bret
So what duration would you recommend for optimum performance?
Old Oct 24, 2005 | 01:42 PM
Re: RWHP To Expect
depends on a lot of things... lift, valve size, heads etc... no set in stone answer
Old Oct 24, 2005 | 03:38 PM
T/A KID's Avatar
Re: RWHP To Expect
Bret your a PIMP when it comes to this stuff
BTW man (take your time on it, because Lloyd has to send the heads to you still) but you should be getting my super Vic setup within a few days or so.
Later Ben
Old Oct 24, 2005 | 05:37 PM
JustNO's Avatar
Re: RWHP To Expect
Bret I said according to thread owner's specs.. (LE3 heads etc..)
Old Oct 26, 2005 | 02:37 PM
Re: RWHP To Expect
That would be obvious... buy a LE cam with the heads for the setup. You really didn't think I would post the specs?
95chwagon
Oct 16, 2015 12:24 PM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
