RWHP To Expect
RWHP To Expect
Just curious what rwhp yall think I will be putting down on my new motor.
"383"
12.6:1 CR
Eagle Forged 4340 3.75 Stroke
Eagle H Beams 5.7 Length
SRP Forged Flat Tops -5cc 4.030 bore
LE3 Heads
42lb Injectors
BBK 58mm
Crane Cam 240/244 .595/.595
Magnum 1.6rr's
Comp R Lifters
Pacesetter LT's
Summit X Pipe Kit 3inch
Spec Alum Flywhl
Spec Stage 3 clutch
Cloyes Double Roller
"383"
12.6:1 CR
LE3 Heads
42lb Injectors
BBK 58mm
Magnum 1.6rr's
Comp R Lifters
Pacesetter LT's
Spec Alum Flywhl
Spec Stage 3 clutch
Re: RWHP To Expect
Originally Posted by SStrokerAce
413rwhp with a peak around 5900-6000rpm based on the cubes, valve lift and valve size. That's if you get 100% VE at 6000rpm.
Bret
Bret
Re: RWHP To Expect
Originally Posted by JustNO
So you say ~485hp at flywheel with %15 drivetrain loss?? He can't see 500hp ha??
Bret
Re: RWHP To Expect
Basically. One reason why I don't feel that cubes nessesitate more duration is because the valves will choke off the heads pretty quickly and more duration is just going to kill some of that extra TQ that you are trying to make with the extra cubes.
Bret
Bret
Re: RWHP To Expect
Bret your a PIMP when it comes to this stuff
BTW man (take your time on it, because Lloyd has to send the heads to you still) but you should be getting my super Vic setup within a few days or so.
Later Ben
Later Ben
Re: RWHP To Expect
Bret I said according to thread owner's specs.. (LE3 heads etc..)
