runs weird when warm
Old Apr 27, 2006 | 08:42 PM
snack1pack's Avatar
ok i got a 94 a4 z28 and when the car gets warm about 170 degree's, the thing like bogs really bad, if you floor it off the line it will stall, or if you gas it to much anywhere lower than 2k rpm it will sputter and hesitate big time for about 2 seconds then get going...i changed the ICM, plugs, o2's(ac delco) opti is somewhat new, brand new walboro 255 in it..does anyone have any idea's
thanks mike
Old Apr 27, 2006 | 11:19 PM
snack1pack's Avatar
Re: runs weird when warm
does anyone have any idea what the culprit is, i need to get it fixed asap so i can get the thing sold
Old Apr 30, 2006 | 09:28 PM
nodnarb481's Avatar
i have the same exact problem.. i was told to check the coil wire... have you found a solution since this?
Old May 1, 2006 | 02:23 PM
snack1pack's Avatar
i replaced the coil itself and the car ran worse lol
Old May 1, 2006 | 02:34 PM
95okz28's Avatar
My 95 did what sounds to be the samething and it was the coolant temp sensor.
Jan 23, 2015 01:13 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
cmdeshon
Dec 12, 2014 10:51 PM
