Running without Knock Sensor Programmed in PCM
Old Jun 7, 2005 | 12:12 AM
  #16
Kurt Crosbie's Avatar
Re: Running without Knock Sensor Programmed in PCM
What is the name of the tool I would use to check the knock sensor stuff? I thought that since I had some broken valve springs, my code 43 was caused by this. But after reading this, apparently it wasn't because of the valve springs.
Old Jun 7, 2005 | 03:01 AM
  #17
94TA25ann's Avatar
Use a voltage meter, you can get a decent one for around $25-35 at sears.
Old Jun 7, 2005 | 05:24 AM
  #18
"Multi-meter" You need to check both ohms and DC volts.
Old Jun 7, 2005 | 05:58 AM
  #19
I guess I'll be getting a multi-meter. How much do they cost and where can I buy one?
HectorM52
Jul 30, 2017 11:46 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
