running super rich, valve lash wrong??
Old Apr 23, 2006 | 09:48 PM
  #16
djlunchbox's Avatar
Re: running super rich, valve lash wrong??
Originally Posted by Stoopalini
I would also recommend doing it with the covers off. You won't get oil all over the place. At idle, oil will be just coming up the pushrod and drain over the rockers. It won't spray out beyond the valve cover mating surface (unless you rev the engine up).
Thomas.
really? hmmm.... i started it without the covers on before and i had oil launch all over the wall in the garage. mine idles at 900 rpm. i'll try it again though, thanks for the heads up
Old Apr 23, 2006 | 09:53 PM
  #17
Loadre's Avatar
Each motor is different, but once it gets hot it'll definetely shoot oil.
Old Apr 23, 2006 | 10:21 PM
  #18
djlunchbox's Avatar
it runs at 50 psi at idle, i'm not sure if that is stock pressure or not. i have a high output pump. runs around 60-65 psi when driving
Old Apr 23, 2006 | 10:53 PM
  #19
Stoopalini's Avatar
At cold idle, my oil pressure sits about 60psi with the stock pump, and it wasn't shooting out past the heads. I had brand new GM lifters, chromoly pushrods, and scorpion rockers. My car idles around 750 or so.
Thomas.
Old Apr 24, 2006 | 06:48 PM
  #20
djlunchbox's Avatar
Thomas.
would the fact that i run 20w/50 have anything to do with it? the builder told me to run that because it was a race only motor (before he did the cam swap ) and it had oil blow-by by the rings.
Old Apr 24, 2006 | 07:02 PM
  #21
Loadre's Avatar
Yes that's a very heavy oil.
Old Apr 25, 2006 | 02:15 AM
  #22
smoknta's Avatar
I'm running Kendall GT 20w50 in my 383 with no issues.
Old Apr 25, 2006 | 07:45 AM
  #23
djlunchbox's Avatar
is it necessary though? i'd rather go back to synthetic if i can. the dino oil has blackened really quick, and the synthetic stayed nice and light for over a year. i found some "Q" 20w-50 that i'll try, although i usually stay away from quaker state and penzoil. do you think 10-40 wold be too light for a race motor?
Old Apr 26, 2006 | 12:47 AM
  #24
smoknta's Avatar
Your oil probably blackened because of it running super rich.
Old Apr 26, 2006 | 09:06 AM
  #25
djlunchbox's Avatar
i never thought of that... you're right
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Deadbolt24
Jan 19, 2015 01:29 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
