Running Rich - Scan Results Inside - Help!
Old Mar 17, 2005 | 10:41 AM
Kataklysm's Avatar
Alright the car has been getting 200 miles per tank while driving light, this is combined city and highway driving. I have no internal upgrades or anything that should be hogging more gas. I let the car get to its operating temp and wrote down all the results from the scanner :
Baro (HG) - 28.15
LT Fuel Trim - ON
LT Fuel Tr CL - 5
LT Fuel Trm L - 115
LT Fuel Trm R - 116
CC on/off sw - OFF
EVAP DUTY - 0%
EGR DUTY - 0%
Coolant - 185* (this is the hottest the car gets)
IAC Position - 29
Inj L PW - 0 MV
Inj R Pw - 0 MV
ST Fuel Trim L - 124
ST Fuel Trim R - 124
Knock Ret - 0*
Knock Sensor - 20
Loop - Closed
MAF (GR/SEC) - 8
MAP - 1.27 V
IAT (F*) - -40
O2 Right - 100-900 MV
O2 Left - 100-900 MV
Spark Advance - 19*
TPS - 0.65 V
Can anyone see something wrong here? It's been like this over a year now, A4 3.23 gears, Ram air, MAC headers, Hooker-Catback, Air foil, TB Bypass have been done. Thanks for any help!
Old Mar 17, 2005 | 11:06 AM
StngStlkr's Avatar
Re: Running Rich - Scan Results Inside - Help!
The first problem I see is that for whatever reason you're not getting any pulse width readings(Inj L PW - 0 MV Inj R Pw - 0 MV). What type of scanner are you using?
Old Mar 17, 2005 | 11:10 AM
Kataklysm's Avatar
Actron
Old Mar 17, 2005 | 11:16 AM
Looking at a single "frame" from a scanner doesn't tell you too much. As noted in the post above, while most of the data looks "normal", some of it makes no sense at all. Appears you are at idle, but looks like it may be in Cell 5. It should be in Cell 16 it idle. And, even though you show 8 grams/sec of air flow, the "0" injector pulse widths are obviously incorrect.
Everything else looks OK. One question... what is your elevation above sea level, just to check if the "barometer" value is logical? Looks like you might be at about 1,000-ft (not in Boston ), or there was a low barometric pressure in Boston?
Old Mar 17, 2005 | 11:21 AM
StngStlkr's Avatar
Weather.com tells me the baro press. in Boston right now is 29.959
Old Mar 17, 2005 | 11:50 AM
Kataklysm's Avatar
The car was at idle...why wouldn't the pulse width be showing up? I don't know anyone else with a scanner and I'm not paying GM $80 to tell me nothing I don't know already.
Old Mar 17, 2005 | 12:22 PM
StngStlkr's Avatar
I don't know why the pulse width wouldn't show up. Maybe try scanning again?
Like Injuneer said though, at idle the cell should be 16. Your longterm fuel trims do seem to be a bit rich 115/116 as compared to 128(currently mine are about 108-113...lol).
Have you modified the MAF in any way? Ported, descreened, etc?
Mine is descreened, and I've noticed it running rich for a while now. If I unplug the MAF the BLM's jump right back to 128. Plug the MAF back in and they drop down to 108-113. Definitely not something right there.
Old Mar 17, 2005 | 12:47 PM
Kataklysm's Avatar
MAF is stock with the screen still in it. It does have an aftermarket fuel pressure regulator from the previous owner but when I tested the fuel pressure it was normal with 40 psi at idle.
DirtyDaveW
Dec 1, 2016 05:37 PM
95chwagon
Feb 28, 2015 12:02 PM
Iamherefornow
Jan 26, 2015 04:57 PM
jayblev95
Jan 20, 2015 01:30 PM
squarehead
Nov 21, 2014 08:02 PM
