Running rich
Old Sep 16, 2011 | 12:36 PM
  #16
bw_hunter's Avatar
Re: Running rich
Originally Posted by Bails098
So i unhooked the o2 sensors and the bad idle is gone. Im gonna run new wires for the 02 sensors and hope that fixes my problem. hopefully it wasnt just because it wouldnt go into closed loop.
Trace the harness all the way back to the PCM. I'm wondering if the heater circuit for the O2's is common somewhere along the harness, making it possible to have the bleed Injuneer mentioned...
Old Sep 17, 2011 | 03:30 PM
  #17
Bails098's Avatar
Re: Running rich
I disconnected the heater wires from the o2 and the numbers are much better and the car is running much better except at idle. The o2 numbers have the variance from 0-0.9v.
It still has a nasty stumble because of a really rich condition. i cant figure out why. Again it does not have that stumble when the car is in open loop only when in closed loop.
I noticed the fuel trim cell goes up to about 16 or 18 when idleing and the charcoal canister purge duty cycle has no reading. When the charcoal canister purge duty cycle percent is around 11 fuel trim is 6. Seems like whenever there is a reading on the ccpdc the fuel trim is much lower. Im not sure if this has anything to do with it but i figured id mention it.
Old Sep 17, 2011 | 06:56 PM
  #18
Re: Running rich
The fuel cell # is determined by a grid of RPM and engine load (MAP). It is not determined by the EVAP purge duty cycle. It's the other way around - the EVAP purge duty cycle is probably triggered by the RPM/MAP combination.
For an overview of the PCM's air/fuel control, read the air/fuel control section of this:
http://www.injuneer.com/ScanMast.html
Old Sep 18, 2011 | 02:21 PM
  #19
Bails098's Avatar
Re: Running rich
Thanks i read that it gives me a good understanding of how everything works. Im gonna work on figuring out my problem and i'll post back results incase anyone else has a similar problem.
Old Sep 18, 2011 | 02:54 PM
  #20
Re: Running rich
I downloaded your DataMaster file, but its on my PC at work. I looked at it briefly. I'll take another look at it Monday.
Old Sep 19, 2011 | 04:05 PM
  #21
Bails098's Avatar
Re: Running rich
thanks I appreciate the help
Old Sep 20, 2011 | 03:51 PM
  #22
Bails098's Avatar
Re: Running rich
My IAC pos counts at idle are at 125 and as high as 145 does this seem right...
The article that injuneer gave me to read said they should be between 20-40 counts at idle. Could this cause my rich problem...
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
