Running Rich
Old Jun 12, 2005 | 01:37 PM
Dtimekw's Avatar
Running Rich
Can anyone shed some light on my fuel(?)problem? At idle, I am running rich, not enough to blow black, but the exhaust smell keeps the mosquitos away (along with the neighborhood kids). My plugs read good. My fuel mileage is about 10mpg. I have had the car for about six months so I am not sure if this is normal. Any help would be great. Thanks.
Old Jun 12, 2005 | 01:50 PM
Re: Running Rich
With no cats, you'll smell unburned fuel. The cats are there to oxidize the unburned hydrocarbons.
You need to get a scanner on it and look at the O2 sensor readings at WOT.... might show you if its really running rich at WOT (although the stock, narrow-band sensors aren't really accurate at the A/F ratios required for peak torque/HP). Then look at the long term fuel corrections. If they are elevated, it might mean the PCM is adding fuel the engine doesn't need. Causes of a "false lean" might include leaks in the exhaust in front of the O2 sensors, misfires or faulty O2 sensors or wiring.
Old Jun 12, 2005 | 02:32 PM
Dtimekw's Avatar
Re: Running Rich
buying a scan tools as we speak. Thanks for the insight.
Old Jun 12, 2005 | 11:13 PM
Re: Running Rich
After you get the scan tool, read this before you use it
http://members.aol.com/InjuneerZZ/ScanMast.htm
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
