running rich??
Old Sep 15, 2003 | 08:30 AM
1QUIKTA's Avatar
running rich??
I am trying to figure out this problem. My car is a 94 Trans Am with the typical bolt ons. Headers (MAC), CAI, Exhaust, etc. I have stock injectors, TB, fuel pump. I have also blocked off the AIR and EGR systems and added new O2 sensors. The programming is through pcmforless and is a conservitive program. He even changed the values once and still the same thing. I am pouring out black smoke and the plugs are fouling in very little time. I just changed them this past winter/spring and have put around 1-2K miles on the car since them (mostly to the track and back, I don't drive the car everyday). Could I have a bad fuel pressure regulator? The car even smell rich during idle.
What else can I check? If anymore info is needed, let me know.
TIA,
Chris
Old Sep 16, 2003 | 07:51 AM
1QUIKTA's Avatar
Any suggestions??
Old Sep 16, 2003 | 08:21 AM
tabroker's Avatar
clean the MAF
Remove your MAF and clean it with a spray-on cleaner, carb cleaner, throttle body cleaner, etc.... This should help your metering and clear up your idle richness problem.
Old Sep 16, 2003 | 08:40 AM
1QUIKTA's Avatar
Thanks for the suggestion, I will try that tomorrow.
I really don't think it is my programming, Bryan has worked with me on that and it never really helped. I think something else on the car is a miss. After all, I did drop .4 with the programming and headers (did both at the same time).
Old Sep 18, 2003 | 10:22 PM
1QUIKTA's Avatar
Well I can mark 2 things off
1)checked for injector leakage and no bleeding of fuel pressure
2)check for bad fuel pressure regulator and no fluid on the vacuum side.
Guess I will try and borrow someones stock pcm and see how that runs.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
